Home Monitor Shows No Devices
Home Monitor is saying I have ‘no devices available for monitoring yet’, even though I have 3 contact sensors and have selected them in the set up for both armed away and armed stay.
Has anyone had this problem before?
Thanks in advance
what are the brand/model of the sensors? what driver is being used?
can you post a screenshot of where you are not seeing them listed? I am wondering if it is the field where you need to tap on to select them before they are visible.
Thanks - They’re z-wave contact sensors (Ring). Driver is the SmartThings Z-wave sensor driver.
Photos attached
I don’t use home monitor, but based on the icons your devices may not be onboarded correctly, check the driver.
There seems an onboarding issue. I had faced the same issue.
