Trying to avoid using the smartthings api integration with home assistant
I basically want to get motion triggers from my eufy cameras from home assistant into smartthings
I discovered this guy fison67 has an integration
Has anyone used this? Would this allow me to get motion alerts from the cameras in ha into smartthings as triggers?
If not is anyone is working on some fancy edge integration with home assistant?
I think the easiest thing would be to create a virtual switch in SmartThings. Then, in Home Assistant, create an automation triggered by the camera motion with an action to turn on that virtual switch (and turn it back off when motion stops).
This might be a little late. I have Eufy cameras in Alexa and I have Alexa routines trigger and set a virtual motion sensor that is owned by Smartthings. On the Smartthings side I have the regular rules that are triggered by motion that turn on outdoor lighting. I also have a rule that turns off the motion indicator of the virtual motion sensor after a minute or 30 seconds depending on the situation.
