I’m not sure if this is the right category so please let me know if I need to post elsewhere
I have been using the SmartThings API to obtain historical data using requests such as…
https://api.smartthings.com/v1/history/devices?locationId=xx&limit=300&pagingAfterEpoch=yyy&oldestFirst=true&pagingOffset=0
which normally works OK. However, on rare occasions, I have noticed that data can be missing from the results.
For example, using the pagingAfterEpoch value that was returned from the previous request in the “next” link, I could get back 10 results for a location and looking at the timestamps there could be an event that was missed between the first and last timestamps in the results.
However, querying the API with the same parameters 10 minutes later returns the correct results.
I understand that sometimes in such asynchronous systems that some events may be delayed and so I expected that instead of using pagingAfterEpoch, pagingAafterHash should do a better job of ensuring no events are missed.
It’s not clear how the hash values are generated but I would expect that using the pagingAfterHash value from the “next” link would give me the correct data. However, the pagingAFterHash parameter appears to have no effect and always returns the latest data.
At the moment, there appears to be no way to identify missing values in the data and ensure that I always get all the data with no gaps.
Note that when it does happen, it seems to be when the system is under stress and events are 5 to 10 minutes behind real time. When the system is not under stress, it appears never to miss values.
I understand that this API call is on the old architecture, so any alternative approach might also work. I’d prefer to move to subscriptions but as I understand it, I need an OAUTH integration for that and that is not not being made publicly available right now.
