Hidden automation routine
After upgrading to the latest app, I noticed that one of the automation routines was not shown. The automation is still working but since it is not shown, I can not modify the routine. How can I bring this routine visible?
…Hans
If android, have you tried clearing your app data cache?
How do you clear that
As an iOS user, I can not say. Not even sure it will fix the hidden automation… just something to try :slight_smile:
You can also contact ST support and have them investigate.
Thanks, I will try to contact ST support.
Press and hold SmartThings icon until Pop-up shows up and select Info
Than select Storage
And select clear Cache.
How do you do that on an Iphone?
Hey there! @Hanskb, the troubleshooting method of clearing the cache, should be located In your Settings Menu for Applications, Select Smart Things from the eligible application list and there should be an option to “Clear Cache” located near the bottom of the settings. I do not have an IOS device to confirm the pathway, I’m sure another community member will chime in to confirm for sure.
As mentioned If the symptom persists, I would recommend creating a Support ticket so we can look into your concerns further.
You can reach out directly to a support team in your area using the below information:
US: 1-866-813-2404
US: support@smartthings.com
UK support 0333 0000333
UK: support@smartthings.co.uk
CA: support@smartthings.ca
I hope this message finds you well!
^SamsungZell
