I have light that is controlled by a 4-way circuit. Only one of the switch locations has a neutral, so I thought about wiring an Aeotec Micro Smart switch at the light. Can anyone tell by looking at this pic as to how it should be wired?
Sorry, wiring the aeon micro switch at the light wont work… It requires constant power and when you turn off your current switches you will also turn off the micro switch.
The only way is to get a multi-meter and check your wiring and wire it to the right switch. The correct wiring diagram is in the manual:
How can i give constant power to aeotec micro switch?
The setup i have makes the switch useless (when i turn off manually, i wont be able to turn on from ST)
