So I bought a zigbee ultrasonic tuya sensor and I’d like to get it to work with smartthings. TZE204_7yyuo8sr is the device but there seems to be very little info on it.
So since its a ef00 tuya device I decided to try using Public SmartThings Edge Drivers - w3513y driver and figured that setting it up as a window shade would work. So I did and I found out that dp 22 shows the percentage of the sensor and I do get feedback, but it seems to go off the maximum 5m depth. I cant seem to think of a way to decrease the depth. Does anyone have any other ideas? Thanks so much for any help.
You are awesome! These drivers are amazing and are fixing so many devices i had before that I had to use dp info! You fixed so many of my issues with my soil sensors as well as a tds sensor I just bought. Thank you so much!
So this driver seems to work fine with the ultrasonic sensor, but i have an issue with the measurement. It only allows meters. I wanted to install this on a 5 gallon bucket. 1 meter is too high. Is there any way it can be changed to centimeters instead?
