Hi all, This is kind of an extension of another thread I started, but it’s now morphed more into help with debugging than an actual idea. Let me start off by stating I had help with the writing this code, so I don’t fully understand what the subscribe part of the code is doing. I am also just beginning to understand how to use and write within smartThings, so please forgive my newbie-ness.
I have this app that creates child devices when I send something like this:
https://graph.api.smartthings.com/api/token/${state.accessToken}/smartapps/installations/${app.id}/Notify?device=window1&type=ContactSensor&state=open
The app mostly works. It creates the child device but never sets the state.
The error I get is follows:
This is what the browser returns:
{“error”:true,“type”:“java.lang.IllegalArgumentException”,“message”:“An unexpected error occurred.”}
This is what the log returns:
12:17:49 PM CST: error java.lang.IllegalArgumentException: argument type mismatch @ line 100
Line 100 is where I attempt to subscribe.
* AT&T Digital Life Hub
* Copyright 2014 Joe Rosiak
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
definition(
name: "AT&T Digital Life Hub",
namespace: "keo",
author: "Joe Rosiak",
description: "Interfaces AT&T Digital Life with SmartThings by using the email notifications from ATTDL. This requires a way to run a email rule on the message body. The rule then triggers an html call to SmartThings. This app will also create a child device in SmartThings or Update the state of the child device if one exists.",
category: "My Apps",
iconUrl: "https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience.png",
iconX2Url: "https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience@2x.png")
preferences {
section("AT&T Sensors") {
// TODO: put inputs here
def installed() {
log.debug "Installed with settings: ${settings}"
initialize()
def updated() {
log.debug "Updated with settings: ${settings}"
unsubscribe()
initialize()
def initialize() {
setupWebNotify()
def setupWebNotify() {
if (!state.accessToken) {
createAccessToken()
// url to call from your web service
log.trace "https://graph.api.smartthings.com/api/token/${state.accessToken}/smartapps/installations/${app.id}/Notify"
mappings {
path("/Notify") {
action: [
GET: "webNotifyCallback"
// url would be /Notify?device=<yourdevicename>&type=ContactSensor&state=<open or closed>
def webNotifyCallback() {
log.trace "get: " + params
// get the inputs from the URL
def deviceDNI = params?.device
def deviceType = params?.type
def deviceState = params?.state
log.debug "${deviceDNI} : ${deviceType} : ${deviceState}"
// see if the specified device exists and create it if it does not exist
def d = getChildDevice(deviceDNI)
log.debug "d = ${d}"
if(!d) {
// convert from input device type into ST device type
def STDeviceType = null
if (deviceType == "ContactSensor") {
STDeviceType = "ATT Contact Switch"
//STDeviceType = "Open/Closed Sensor"
} else {
log.debug "Unknown Device Type"
if (STDeviceType) {
// we have a valid device type, create it
d = addChildDevice("keo", STDeviceType, deviceDNI, null, [label:"AT&T ${deviceDNI}"])
//d = addChildDevice("smartthings", STDeviceType, deviceDNI, null, [label:"AT&T ${deviceDNI}"])
log.trace "created ${d.displayName} with id $yourDeviceDNI"
} else {
log.trace "found ${d.displayName} with id $yourDeviceDNI already exists"
if (d) {
//subscribeAll()
subscribe(physicalgraph.app.DeviceWrapper)
subscribe(physicalgraph.app.AttributeWrapper, java.util.Map)
// we have a valid device that existed or was just created, now set the state
log.trace "${d.displayName} = ${deviceState}"
if (deviceState == "open") {
// call the open function in the device type, make sure it exists and sets the device state
d.open()
} else if (deviceState == "closed") {
log.trace "setting device state to ${deviceState}"
// call the close function in the device type, make sure it exists and sets the device state
d.close()
} else {
log.debug "unknown device state = ${deviceState}"
