The reason that it gets stuck on “Identifying” is because it’s not a certified device. We have to add a “fingerprint” to our platform so that we know what device you’re pairing. As this isn’t a supported device, there’s no fingerprint that matches it on our system.
unfortunately, i haven’t been able to reset the bulb again so i’ve had to contact osram support.
am i right in saying that, assuming that i can get the bulb reset, i can log in to the url that you provided on my phone and then start the app on my phone and you’ll get the log that you require?
What I found was that you may need to delete the bulb from the smart things app first (you will need to also delete/remove any rules/smart apps that is associated with that bulb first before it will allow you to delete the bulb for the app)
Then go through the 5sec ON, 5sec off 5times to reset the bulb it will blink ONCE. Then on Smart things app search for new devices “general” search wait 60 secs if it does not pick it up turn the bulb off and on and wait a few minutes. If it still does not pick it up the yes, custom device type maybe required. Although not an officially supported bulb I have 4 working - but I am running custom device types to better suit my personal preference. I’ve also reset these bulbs numerous times.
so, i’ve got a new bulb and i still can’t reset it so it seems that it’s something i’m doing rather than a faulty bulb.
does the bulb need to be next to the hub for a reset or can it be anywhere?
my bulb is in a lamp with a dimmer. would that make any difference? grasping at straws here …
and just to clarify - say my lamp is off. should the bulb blink straight after the 5th ON or will i have to turn it off again and the blink happens on what is effectively the 6th ON?
thanks in advance for your help. this whole things is extremely frustrating. the motion sensor is useless because of my pets. i’m still waiting for support to get back to me regarding the faulty socket switch so i’ve basically paid a lot of cash for a useless white box at this point.
The 5th time or the 6th time doesn’t matter really but wait for 10 seconds I find it flashes once after 5-8 secs. Then click on search for new devices in ST app. Turn off the bulb for 2 secs then turn it back on. The bulb should then flash again and after 5-10 secs the app should pick up the new bulb.
My hub is on the middle floor, bulb is ground floor approx 5m away and through the ceiling. So distance shouldn’t be a problem. Dimmer should be ok but worth trying it in a non dimmer or max the brightness and switch the actual switch off/on if you can rather than 100 down to 0 through the dim if that makes sense??
have been repeating the procedure that you describe multiple times without success. bit of a nightmare for something so simple and the wife thinks i’m demented.
i have tried both unscrewing the bulb and switching off at the mains (rather than dimming) to no avail.
have also tried moving closer to the hub again to no avail.
not sure that i have another lamp but will have a look as that’s the only thing that i can think if that i haven’t tried.
Hi, I’m trying to add the same bulb but without success.
The app identifies the bulb but it doesn’t match any device.
I tried to set many of them (the other OSRAM bulbs, the generico zigbee switch, and some others) but no one works.
I checked in the log while identifying the device but I can’t see any log for this device (btw, I’m using graph.api.smartthings.com, not graph-eu01-euwest1.api.smartthings.com, as my hubs are registered in the first one). I tried many times removing from the network and adding it again.
Can you look at the bulb in the My Devices section of the IDE? Clicking on it there will bring up a bunch of info. One item is called Raw Description. Copy that here. It should look like a long string of 2 and 4 digit number strings.
If you paired the bulb recently, try going to your hub’s page and clicking List Events, then filter on All at the top. You should see a Join event for the bulb and the description would have the info hopefully.
You may need to reset and re-pair the bulb to the hub (closer is better). It seems like the bulb may not have passed all the messages during join.
Looks like it’s using endpoint 3 and for some reason the generic ST devicetypes aren’t picking it up right. Same thing happened with the light in the thread above.
If you need with applying custom code, here’s an FAQ thread about it.
Dimming doesn’t work? It looks like it should from a product and code perspective. If you want to start Live Logging in the IDE and try dimming in the app to see if it throws an error, maybe I can help.
If there’s no error in the log, then it’s most likely either an ST issue and might resolve itself or interference on the 2.4ghz band.
Glad it’s working! I’ve seen a couple reports of dimming not working on other devices that should work, so it might correct itself for @mrdo.
In @mrdo post above where he pasted in a screen capture of some live logging. The join messages are there. The description one is blank, which is why raw description was also blank; but the 3rd one down says there’s one endpoint and it’s endpoint 3.
