Thanks so much. I just updated my settings. So far so good!
Has anybody with this device moved over and got it working in hubitat?
I do. I wouldnt say it’s pretty, but I have it working.
I’ll post my code over on hubitat.
FWIW Here is another DH that I significantly modified based on the 3A Nue 2 Gang switch. I have added default on/off actions and a config option to choose what switch the action applies to (SW1, SW2 or Both) Also deals with catch all for when the switch is manually toggled.
Hi Netsheriff,
I find the same with the 2-gang DTH. Switch2 status changes after a manual change, but Switch1 doesn’t.
Also, I recommend installing Pollster to force status updates for your smart switches
Looks like device health isn’t updating anymore.
Last update was Mon Aug 19 05:27:00 UTC
Also a bunch of my devices are shown as unavailable (despite still working if i toggle them in the smartthings app).
Anyone else having issues?
@3asmarthome any device handler updates available?
I’m new to ST. I have been using the A3 switches on their hub for a while, but the app is a bit limited. So I swapped the double GPO on ST a few months ago, then recently it stopped working. I’ve tried the updated DH from A3 but no luck. I tried the DH that you modified, which is nicer and the logs show the on off events. But nothing happens. Nothing comes back from the switch either. After joining the switch, the red light (behind the glass pannel) stays on. It makes me think that the join isn’t right. The DH endpoints look right.
zbjoin: {“dni”:“40CB”,“d”:“00158D0001FF5E92”,“capabilities”:“8E”,“endpoints”:[{“simple”:“0B C05E 0000 01 07 0000 0004 0003 0006 0005 1000 0008 01 0019”,“application”:“01”,“manufacturer”:“FeiBit”,“model”:“FNB56-SKT1DHG1.4”},{“simple”:“0C C05E 0000 01 06 0000 0004 0003 0006 0005 0008 01 0019”,“application”:“01”,“manufacturer”:“FeiBit”,“model”:“FNB56-SKT1DHG1.4”}],“parent”:“1072”,“joinType”:1}
Can the 3 gang DH/App be modified to accommodate 4 gang?
It’s not a 4 gang, it’s a scene switch, so I doubt it.
Can you help me to do the same? Im new at this!
Hi All,
Attached are DH and Binder for the 4 Gang switch.
(although I believe I am the buyer of the last one available in Australia!).
Thanks to all the previous developers to make my job easier in building these for the 4Gang.
Binder: https://pastebin.com/z5uGqGcr
DH: https://pastebin.com/z5uGqGcr
You will need ST Classic to create the SmartApp and assign the virtual switches.
Once done, each switch will show in SmartThings.
@Andrea_Quattrone
Will this work with the following 4 gang switch :
https://www.aliexpress.com/item/4000406084664.html
Thanks for your work !!
Thanks,
Can you make it more generic so any 4 gang switch will work ?
Hi Kortex,
Have you got an update to these DH and smart apps. I am having constant christmas light issue lately with my 2 Gang & 3 gand switches.
I am using the following Feibit Inc Co. switches
FB56+ZSW1HKJ2.5 - 2 Gang Switch - HGZB-042
FB56+ZSW1IKJ2.5 - 3 Gang Switch - HGZB-043
I am using these DH & Smartapp
2 Gang DH https://pastebin.com/QpeCFUUA
3 Gang DH https://pastebin.com/d1ayFf9j
2 Gang Smart App https://pastebin.com/V18E93ni
3 Gang Smart App https://pastebin.com/Pj51hUas
Please help
Hi I found Eric M (erocm1231}'s modified DH which works very well with his Virtual Device Sync Create Virtual Devices and Keep Them In Sync With a Physical Device
DH
2-gang:
https://pastebin.com/J5Mr0Psd
3-gang:
https://pastebin.com/t4gRLxr5
So far this is working very well. Will monitor and advise. Hope this helps someone
