Im trying to take a handler from a example and change a few things. So I thought if I just make changes I could then add it to my handlers and use it. But when I try saving it I get this message
Org.springframework.security.access.AccessDeniedException: Run Locally Permission not allowed for DeviceType: bcc90d0f-217e-4f7a-8617-5df0ba4c0b0e
I just want to change it so it shows open and closed and not on or off.
I want the switch to show open and close on the app and not on or off. I got it but I messed the code up because now it shows OPEN but I cant close it lol. I found a way to make the switch open my garage door using a 12v power supply and a 12v relay. And in the app I set up the power allowance to turn the switch off after 0 mins. So when I turn it on it turns right off but its enough time to trigger the relay.
You could get pretty creative with device handlers, but I’ve not done anything like that except through SmartApps. I prefer to keep DTH’s relatively straight forward for using the device, and then apps to manipulate them based on rules or conditions.
Put it near the end of the command you want the timer to start. You could get fancy and have the time as a preference which could be changed in the app
