Can’t access webcore anymore. The stickys at the bottom just spin. I was modifying a couple of pistons. I saved them and now I can’t get back to them. I installed another instance and I can access that fine. Of course I’m new to webcore and didn’t enable automatic backups!
Go to the webcore app and go to settings and choose clean and rebuild data. Does that fix it? If not, do you have any errors in the IDE?
hi! Thanks for the quick reply. The clean and rebuild does not work. I do have auth errors in the IDE.
9d1a77b9-ab6a-49a7-8332-3a5d47a87f63 9:24:10 PM: error java.lang.NullPointerException
9d1a77b9-ab6a-49a7-8332-3a5d47a87f63 9:24:10 PM: error Dashboard: Authentication failed due to an invalid token
9d1a77b9-ab6a-49a7-8332-3a5d47a87f63 9:23:43 PM: error Dashboard: Authentication failed due to an invalid token
In the IDE I refreshed my client secret. Now I only get the following error.
9d1a77b9-ab6a-49a7-8332-3a5d47a87f63 9:33:22 PM: error java.lang.NullPointerException
9d1a77b9-ab6a-49a7-8332-3a5d47a87f63 9:33:03 PM: error java.lang.NullPointerException
Go to dashboard.webcore.co/register and try registering the instance again
Thanks…I’ve tried that several times as well. No luck!
Question…I copied the code from my piston earlier today to a text file. Any way to copy and paste to a new instance?
I think your pistons are just fine, it’s a matter of fixing the access tokens - should have not reset the OAuth.
Yeah the pistons are still running ok, but I just can’t access them.
