Help to "Round" in a SmartApp
I use the below SmartApp to alert me and flash a bulb, when a window sensor has been left open for x minutes, and continously alert me every y minutes, until closed. I’m very happy with it, it works just as it should.
Besides one small thing. In the notification it says: “Bathroom windows has been left open for 40.0142546 minutes.”.
It “hurts” my eyes, it hasn’t been rounded to “… 40 minutes…”. It should be just 40, without any decimal points. Regretably I have no training/knowledge about SmartApp coding.
  • Could anyone help me with which codelines should be changed to what, to achive rounding with no decimals in the alerts from this app, thanx?
  • Gatekeeper
  • Copyright 2015 Herbert Carroll
  • Licensed under the Apache License, Version 2.0 (the “License”); you may not use this file except
  • in compliance with the License. You may obtain a copy of the License at:
  •  http://www.apache.org/licenses/LICENSE-2.0
  • Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
  • on an “AS IS” BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
  • for the specific language governing permissions and limitations under the License.
definition(
namespace: “herbcarroll”,
author: “Herbert Carroll”,
description: “Watches a gate or door and alerts if left open for longer than a defined number of seconds.”,
category: “My Apps”,
iconUrl: “https://raw.githubusercontent.com/herbcarroll/resources/master/stIcons/doors-active.png”,
iconX2Url: “https://raw.githubusercontent.com/herbcarroll/resources/master/stIcons/doors-active%402x.png”,
iconX3Url: “https://raw.githubusercontent.com/herbcarroll/resources/master/stIcons/doors-active%402x.png”,
preferences {
section ("Which gate, door , or window sensor should we watch?")
	input "contactSensors", "capability.contactSensor", title: "Enter a contact sensor to monitor", required : true, multiple: false
section("How many seconds do you want to allow the door to remain open before alerting?")
	input "seconds", "number", title: "The number of seconds to wait before alerting the first time", range: "5..*", required: true;
    input "secsNext", "number", title: "The number of seconds to wait subsequent alerts", range: "10..*", required: true;
section("Which lights do you want to flash...")
		input "switches", "capability.switch", title: "Flash these lights", multiple: true, required : false
		input "numFlashes", "number", title: "Flash them this many times.  (default 3)", range : "1..10", required: false
//on for 3 secs, off for 3 works best
//section("Time settings in milliseconds (optional)...")
//	input "onFor", "number", title: "On for (default 1000)", required: false
//	input "offFor", "number", title: "Off for (default 1000)", required: false
section( "Notifications" )
	input "sendPushMessage", "enum", title: "Send a push notification?", metadata:[values:["Yes","No"]], required:false
def installed() {
log.debug “Installed with settings: ${settings}”
initialize()
def updated() {
log.debug “Updated with settings: ${settings}”
unsubscribe()
initialize()
def initialize() {
subscribe(contactSensors, “contact.open”, doorOpened );
subscribe(contactSensors, “contact.closed”, doorClosed );
//subscribe(switches, “switch”, flashingLightsHandler );
def doorOpened(evt)
log.debug “door open checking in ${seconds} seconds!”;
state.TimeOpened= now();
runIn(seconds, checkIfStillOpened, [overwrite : true] );
def doorClosed(evt) {
log.debug “door closed!”;
if ( state.TimeOpened && state.alert )
reportClosed(now()-state.TimeOpened);
state.alert=false;
state.TimeOpened= null;
state.flashing = false; //stop flashing that may be going on
def checkIfStillOpened( )
log.debug "checking door… door " + (state.TimeOpened ? “still opened!” : “was closed!”);
if (!state.TimeOpened)
return;
if ( contactSensors.currentValue(“contact”)==“closed”)
//sendMessage( “Warning. Contact was found to be closed by state.TimeOpened is not null ${state.TimeOpened}”);
state.TimeOpened=null;
return;
def falseAlarm = now()-state.TimeOpened < seconds;
log.debug "Time elapsed since opened is ${now()-state.TimeOpened} which should be more than ${seconds}.  Therefore false alaram = ${falseAlarm}";
//runIn overwrite=true negates the need to check for false alarms
reportOpened(now()-state.TimeOpened);
state.alert=true;
flashLights();
runIn(secsNext, checkIfStillOpened );
private reportClosed( msecs )
def secs = msecs/1000;
if ( secs < 60 )
sendMessage ("{contactSensors.displayName} closed after {secs} seconds!");
return;
def mins = secs/60;
sendMessage ("{contactSensors.displayName} closed after {mins} minutes!");
private reportOpened( msecs )
if ( secs < 60 )
sendMessage ("{contactSensors.displayName} left opened {secs} seconds!");
return;
def mins = secs/60;
sendMessage ("{contactSensors.displayName} left opened {mins} minutes!");
def sendMessage( msg )
if ( sendPushMessage == “Yes” )
sendPush(msg)
else
sendNotificationEvent( msg )
private flashLights()
def doFlash = true
def onFor = 3000;
def offFor = 3000;
def numFlashes = numFlashes ?: 3
log.debug "LAST ACTIVATED IS: ${state.lastActivated}"
if (state.lastActivated)
	def elapsed = now() - state.lastActivated
	def sequenceTime = (numFlashes + 1) * (onFor + offFor)
	doFlash = elapsed > sequenceTime
	log.debug "DO FLASH: $doFlash, ELAPSED: $elapsed, LAST ACTIVATED: ${state.lastActivated}"
if (doFlash)
	log.debug "FLASHING $numFlashes times"
	state.lastActivated = now()
	log.debug "LAST ACTIVATED SET TO: ${state.lastActivated}"
	def initialActionOn = switches.collect{it.currentSwitch != "on"}
	def delay = 0L
	numFlashes.times
		log.trace "Switch on after  $delay msec"
		switches.eachWithIndex {s, i -> initialActionOn[i] ?  s.on(delay: delay) :s.off(delay:delay) }
		delay += onFor;
		log.trace "Switch off after $delay msec"
        switches.eachWithIndex {s, i -> initialActionOn[i] ?  s.off(delay: delay) :s.on(delay:delay) }
		delay += offFor
private flashLights_() //event based not used
state.flashing = true;
def lights = switches.collect{it.currentSwitch == “on”};
state.flashes = switches.collect{ (numFlashes?:3) * 2 };
switches.eachWithIndex {s, i -> lights[i] ?  s.off() :s.on() };
state.flashes.eachWithIndex{ s, i -> state.flashes[i]-- };
def flashingLightsHandler( evt )
log.debug “flashing event!”
if ( !state.flashing )
return;
def onFor = onFor ?: 3000
def offFor = offFor ?: 1000
def i  = switches.findIndexOf { it.displayName == evt.displayName };
if ( i == -1 )
	log.debug "unexpected error, event for light no found - switches = ${switches} displayName = ${evt.displayName}, ${evt}";
    return;
def numOfFlashesLeft = state.flashes[i];
if ( numOfFlashesLeft > 0 )
	 evt.value=="on" ? switches[i].off(delay : offFor) : switches[i].on(delay : onFor);
state.flashes[i]=numOfFlashesLeft-1;
log.debug "${state.flashes[i]} flashes left for light ${evt.name} at index ${i}";
state.flashing = state.flashes.any { it-> it > 0 };
if ( state.flashing == false )
	log.debug "flashing done for all lights!, state.flashes = ${state.flashes}";
We can just convert the double to an integer by chopping off remainder. Note the ‘.toInteger()’ I added onto the secs and mins variables when the push notification is sent.
@bban
Thanx.
That worked. Spot on. :muscle: :+1:
