Hi!
I have a Telldus Door/Window magnet sensor (15110) with a tamper switch on the back and need some help to make the tamper work as an extra switch to be able to automate other devices.
(I wanna use it to monitor a door for both open/closed state as well as locked unlocked state via modifying the tamper lever switch)
I use the default “Z-wave Door/Window sensor” example device handler and it works almost as intended, except that it automatically clears the tamper alarm after 10 seconds in up state and thats the problem I need help solving. I want to be able to see if the tamper switch is in down or up state all the time.
I know there are a lot of supersmart people on this forum and that its probably easy to modify the DH code but I dont have the skills (I have tried but with no success) so now Im asking you all for help
Facts:
Sensor: Telldus Door/Window Sensor 15110
Log output is as follows…
Door opens:
debug parsed 'zw device: 25, command: 8003, payload: 64 ’ to [[name:battery, unit:%, value:100, linkText:Telldus Door Sensor 15110, descriptionText:Telldus Door Sensor 15110 battery is 100%, isStateChange:false, displayed:false]]
Door closes:
Tamper pushed down:
debug parsed 'zw device: 25, command: 7105, payload: 00 00 00 FF 07 00 01 03 00 ’ to [[name:tamper, value:clear, linkText:Telldus Door Sensor 15110, descriptionText:Telldus Door Sensor 15110 tamper is clear, isStateChange:false, displayed:false]]
Tamper pulled up:
debug parsed 'zw device: 25, command: 7105, payload: 00 00 00 FF 07 03 00 00 ’ to [[name:tamper, value:detected, descriptionText:Telldus Door Sensor 15110 was tampered, linkText:Telldus Door Sensor 15110, isStateChange:true, displayed:true]]
If its possible to clean out the “reset tamper to clear” in the Smartthings IDE "Z-wave example code it would solve my problem.
Please tell me if I should provide the code for the Z-wave Door/window sensor below (Its the same code that you get in the Samsung Groovy IDE when trying to create a new DH from example)
If anyone could help it would mean the world to me.
Kind regards and thanks in advance!
