Hi!
I’m not really good yet at getting my head around/figuring out how to use things like Routines in ST or IFTTT (or Stringify, etc) to make multiple things happen. Specifically, I’d like to find a way to trigger night time sleep sounds. I have Nightingale which does connect via voice to Google Home but I need additional sound too as it isn’t quite loud enough on its own. Google Home can do a multitude of sounds but I’m looking for a way other than voice to trigger this. I just read about the Flic button in a LifeHacker article (https://lifehacker.com/you-need-a-flic-button-if-you-re-into-smart-homes-1821324815) and they specifically talk about what I’m wanting to do in terms of creating a nighttime routine that turns off all the lights, and starts sound. The reason I don’t want to do this via voice is that my spouse often falls asleep before I do with something quiet on TV but if I have to actually talk to get this working, it will likely wake him up. Could anyone offer any suggestions as to how I might set this up as a Routine in ST (if possible), as an applet in IFTTT, or as a flow in Stringify? I’m hoping that if I could understand how to do this on this particular situation, if may help me figure out how to create more things like it moving forward.
Thanks so much in advance!
Rae
PS I wanted to add one other thoughts…would this work perhaps with an NFC tag somehow? Obviously, I’d have to have the triggers setup already in something else but NFC is much less expensive than Flic. Just curious.
