So i purchased an entertainment console from Walmart and i want to add 2 light strips, both inside with 1 across the top & same for bottom. My issue is the panel in the middle, it doesnt have any type of slight opening totally the strop all the way across. Im not even sure what to do for the bottom. Its compressed wood so not sure if I can drill a hole through it. Now i purchased sengled zigbee lights which I use under my kitchen Cabinet without fail but maybe there is a differnet light strip that would allow me to go around it or maybe a wire that attached from 1 strip to another allowing the gap. Hope someone can help me. I did purchase a console with lights but it was too small. Im also hoping to avoid having to use 4 sets of light strips u less the only way. Thanks again for your help.
Related topics
| Topic | Replies | Views | Activity | |
| Entertainment unit console smart lighting: ideas needed | 1 | 532 | April 4, 2018 | |
| What is a good low cost solution for zwave controlled LED under cabinet lighting? | 29 | 54567 | July 18, 2018 | |
| Recommend a smart under-cabinet kitchen LED lights for kitchen? | 14 | 20068 | October 11, 2017 | |
| Help a noob with under cabinet led products | 26 | 5887 | November 15, 2015 | |
| Smart RGBW strip for under kitchen cabinets? | 7 | 1532 | October 14, 2020 |
