This is my first app from scratch and having a little trouble. Looking for some help.
My use case is simple, I have a routine that shuts a light off. I want this routine execution event to fire a smart app to also check if doors are open (gate, garage, etc ) and notify me if they are. The documentation for Routine Event seems to indicate this is possible, yet I’m having a terrible time getting it to work. I suspect it’s my lack of experience with Groovy and the IDE.
* Routine Triggers Open Door Check
* Copyright 2015 Glen McGowan
definition(
name: "Routine Triggers Open Door Check",
namespace: "mobious",
author: "Glen McGowan",
description: "Check whether door is opened when Routine Executes.",
category: "Convenience",
iconUrl: "http://cdn.device-icons.smartthings.com/Home/home2-icn.png",
iconX2Url: "http://cdn.device-icons.smartthings.com/Home/home2-icn@2x.png"
preferences
page(name: "selectActions")
def selectActions() {
dynamicPage(name: "selectActions", install: true, uninstall: true) {
// Get the available routines
def actions = location.helloHome?.getPhrases()*.label
if (actions) {
// sort them alphabetically
actions.sort()
section("Routine") {
log.trace actions
// use the actions as the options for an enum input
input "action", "enum", title: "Select a trigger routine", options: actions
section("Doors to check"){
input "Door", "capability.contactSensor", title: "Which Doors?", multiple: true, required: true
section("Notification"){
input "sendPush", "bool",title: "Send Push Notification?", required: true
input "phone", "phone", title: "Phone Number (for SMS, optional)", required: false
input "pushAndPhone", "enum", title: "Both Push and SMS?", required: false, options: ["Yes", "No"]
def installed() {
log.debug "Installed with settings: ${settings}"
initialize()
def updated() {
log.debug "Updated with settings: ${settings}"
unsubscribe()
initialize()
def initialize() {
subscribe(location, Door, "routineExecuted", routineChanged, checkDoor, doorCheckHandler)
def routineChanged(evt) {
// name will be "routineExecuted"
log.debug "evt name: ${evt.name}"
// value will be the ID of the SmartApp that created this event
log.debug "evt value: ${evt.value}"
// displayName will be the name of the routine
// e.g., "I'm Back!" or "Goodbye!"
log.debug "evt displayName: ${evt.displayName}"
// descriptionText will be the name of the routine, followed by the action
// e.g., "I'm Back! was executed" or "Goodbye! was executed"
log.debug "evt descriptionText: ${evt.descriptionText}"
def doorCheckHandler(evt) {
log.debug "Detected Routine Complete, Executing Door Check"
if (evt.displayName == action) {
checkDoor()
def checkDoor() {
log.debug "Door ${door.displayName} is ${door.currentContact}"
if (door.currentContact == "open") {
def msg = "${door.displayName} was left open!"
log.info msg
if (!phone || pushAndPhone != "No") {
log.debug "sending push"
sendPush(msg)
if (phone) {
log.debug "sending SMS"
sendSms(phone, msg)
} else {
log.debug "Door Check Complete: No Open Doors"
If I remove doorCheckHandler
and checkDoor
from the def initialize ()
I’m able to see the Routine Event captured in the logs.
However, when I add them back I see the following failure when trying to configure the app and I don’t see the routine events being logged any longer.
What am I doing wrong? Any assistance would be greatly appreciated.
