Hi folks (especially @tonesto7 ) -
I seem to have gotten myself into an bit of a pickle with the Nest Manager installation - I was having a problem with OAUTH and so decided to uninstall all @tonesto7 's Nest Manager smartapps, and reinstall.
The problem is that the NST Automation app will not go away, and I cannot delete it from the IDE because it thinks there’s a user that is using it: “This SmartApp can’t be deleted at this time because it is installed by one or more users”
To make matters worse, when I go to the SmartThings app on my mobile, it shows 5 NST Automations installations, and I cannot delete them. (5 may have been the number of times I tried to reinstall the NST Automation code from github.) Whenever I select one of these apps, it tells me there is a problem and doesn’t present me with a REMOVE option.
Looking for some help here, since I cannot proceed (obviously) until I get that app deleted. Screen shots below…
Thanks in advance - Rob
