Hi,
I am writing an edge driver for a switch with integrated temperature control.
The temperature is provided by ‘DeviceTemperatureConfiguration.attributes.CurrentTemperature’. When the temperature is higher than 70°C, ‘Alarm.client.commands.Alarm’ sends code ‘0x86’ for overheating alarm. When I receive this alarm, I use the temperatureAlert capability to change it to the ‘heat’ state otherwise the state is ‘cleared’. Unfortunately, the alarm_code is not cleared automatically, so I have to reset it with ResetAlarm() or ResetAllAlarms(), which I do in the function below. If the value is below 70°C and the TamperAlert is still ‘heat’ then send a ResetAlarm() or ResetAllAlarms().
local alarm_handler = function(driver, device, zb_rx)
if (zb_rx.body.zcl_body.alarm_code.value == 0x86) then
device:emit_event(capabilities.temperatureAlarm.temperatureAlarm('heat'))
else
device:emit_event(capabilities.temperatureAlarm.temperatureAlarm('cleared'))
end
end
local temperature_handler = function(driver, device, value, zb_rx)
local temp_alarm = device:get_latest_state("main", capabilities.temperatureAlarm.ID,
capabilities.temperatureAlarm.temperatureAlarm.NAME, 'cleared')
device:emit_event(capabilities.temperatureMeasurement.temperature({ value = value.value, unit = 'C' }))
if value.value < 70 and temp_alarm == 'heat' then
device:send(Alarm.server.commands.ResetAllAlarms(device))
--device:send(Alarm.commands.ResetAlarm(device,0x86, 0x0702))
end
end
// Zigbee handlers
zigbee_handlers = {
cluster = {
[Alarm.ID] = {
[Alarm.client.commands.Alarm.ID] = alarm_handler
attr = {
[DeviceTemperatureConfiguration.ID] = {
[DeviceTemperatureConfiguration.attributes.CurrentTemperature.ID] = temperature_handler
The part of the test is like this
test.register_coroutine_test(
"Temperature handled",
function()
test.socket.zigbee:__queue_receive({
mock_device.id,
DeviceTemperatureConfiguration.attributes.CurrentTemperature:build_test_attr_report(mock_device, 44)
test.socket.capability:__expect_send(
mock_device:generate_test_message("main",
capabilities.temperatureMeasurement.temperature({ value = 44, unit = "C" }))
end
function()
mock_device.id,
DeviceTemperatureConfiguration.attributes.CurrentTemperature:build_test_attr_report(mock_device, 70)
capabilities.temperatureMeasurement.temperature({ value = 70, unit = "C" }))
mock_device.id,
Alarm.client.commands.Alarm.build_test_rx(mock_device, 0x86, 0x0702)
mock_device:generate_test_message("main", capabilities.temperatureAlarm.temperatureAlarm.heat())
test.wait_for_events()
mock_device.id,
DeviceTemperatureConfiguration.attributes.CurrentTemperature:build_test_attr_report(mock_device, 65)
capabilities.temperatureMeasurement.temperature({ value = 65, unit = "C" }))
--[[ test.socket.zigbee:__expect_send({
mock_device.id,
Alarm.server.commands.ResetAlarm.build_test_rx(mock_device, 134, 0x0702)
mock_device.id,
Alarm.server.commands.ResetAllAlarms.build_test_rx(mock_device)
end
For both cases ResetAlarm() and ResetAllAlarms() I seem to get the same error in the CLI:
ResetAllAlarms()
Running test "Temperature handled" (1 of 2)
TRACE || Setup driver zigbee_switch with lifecycle handlers:
DeviceLifecycleDispatcher: zigbee_switch
default_handlers:
doConfigure:
driverSwitched:
infoChanged:
init:
TRACE || Zigbee Device: 00000000-1111-2222-3333-000000000001
Manufacturer: AEOTEC Model: ZGA002
[1]: OnOff
DEBUG || driver device thread event handled
TRACE || Received event with handler _resync
TRACE || Found DeviceLifecycleDispatcher handler in zigbee_switch -> Switch
DEBUG || Switch device thread event handled
TRACE || Received event with handler zigbee
INFO || <ZigbeeDevice: 00000000-1111-2222-3333-000000000001 [0x0001] (Switch)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x0001, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: DeviceTemperatureConfiguration >, lqi: 0x00, rssi: 0, body_length: 0x0008, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0000, DataType: Int16, CurrentTemperature: 44 > > > >
TRACE || Found ZigbeeMessageDispatcher handler in zigbee_switch -> Switch
INFO || Executing ZclClusterAttributeValueHandler: cluster: DeviceTemperatureConfiguration, attribute: CurrentTemperature
INFO || <ZigbeeDevice: 00000000-1111-2222-3333-000000000001 [0x0001] (Switch)> emitting event: {"component_id":"main","state":{"unit":"C","value":44},"capability_id":"temperatureMeasurement","attribute_id":"temperature"}
PASSED
Running test "Temperature handled" (2 of 2)
default_handlers:
doConfigure:
driverSwitched:
infoChanged:
init:
[1]: OnOff
INFO || <ZigbeeDevice: 00000000-1111-2222-3333-000000000001 [0x0001] (Switch)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x0001, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: DeviceTemperatureConfiguration >, lqi: 0x00, rssi: 0, body_length: 0x0008, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0000, DataType: Int16, CurrentTemperature: 70 > > > >
INFO || <ZigbeeDevice: 00000000-1111-2222-3333-000000000001 [0x0001] (Switch)> emitting event: {"component_id":"main","state":{"unit":"C","value":70},"capability_id":"temperatureMeasurement","attribute_id":"temperature"}
INFO || <ZigbeeDevice: 00000000-1111-2222-3333-000000000001 [0x0001] (Switch)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x0001, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: Alarms >, lqi: 0x00, rssi: 0, body_length: 0x0006, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x09, seqno: 0x00, ZCLCommandId: 0x00 >, < Alarm || alarm_code: 0x86, cluster_identifier: SimpleMetering > > >
INFO || Executing ZclClusterCommandHandler: cluster: Alarms, command: ResetAlarm
INFO || <ZigbeeDevice: 00000000-1111-2222-3333-000000000001 [0x0001] (Switch)> emitting event: {"component_id":"main","state":{"value":"heat"},"capability_id":"temperatureAlarm","attribute_id":"temperatureAlarm"}
INFO || <ZigbeeDevice: 00000000-1111-2222-3333-000000000001 [0x0001] (Switch)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x0001, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: DeviceTemperatureConfiguration >, lqi: 0x00, rssi: 0, body_length: 0x0008, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0000, DataType: Int16, CurrentTemperature: 65 > > > >
INFO || <ZigbeeDevice: 00000000-1111-2222-3333-000000000001 [0x0001] (Switch)> emitting event: {"component_id":"main","state":{"unit":"C","value":65},"capability_id":"temperatureMeasurement","attribute_id":"temperature"}
INFO || <ZigbeeDevice: 00000000-1111-2222-3333-000000000001 [0x0001] (Switch)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x0001, dest_endpoint: 0x01, profile: 0x0104, cluster: Alarms >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x01, seqno: 0x00, ZCLCommandId: 0x01 >, < ResetAllAlarms || > > >
Failed with message:
Zigbee message channel send was expecting:
ZigbeeMessageRx:
Uint8: 0x00
AddressHeader:
src_addr: 0x0001
src_endpoint: 0x01
dest_addr: 0x0000
dest_endpoint: 0x01
profile: 0x0104
cluster: Alarms
Uint8: 0x00
Int8: 0
Uint16: 0x0003
ZCLMessageBody:
ZCLHeader:
frame_ctrl: 0x01
seqno: 0x00
ZCLCommandId: 0x01
ResetAllAlarms:
but received:
ZigbeeMessageTx:
Uint16: 0x0000
AddressHeader:
src_addr: 0x0000
src_endpoint: 0x01
dest_addr: 0x0001
dest_endpoint: 0x01
profile: 0x0104
cluster: Alarms
ZCLMessageBody:
ZCLHeader:
frame_ctrl: 0x01
seqno: 0x00
ZCLCommandId: 0x01
ResetAllAlarms:
FAILED
Passed 1 of 2 tests
ResetAlarm()
default_handlers:
init:
driverSwitched:
doConfigure:
infoChanged:
child_dispatchers:
DeviceLifecycleDispatcher: zigbee_switch -> Zigbee Hanssem Switch
default_handlers:
init:
[1]: OnOff
INFO || <ZigbeeDevice: 00000000-1111-2222-3333-000000000001 [0x0001] (Switch)> emitting event: {"component_id":"main","state":{"unit":"C","value":44},"attribute_id":"temperature","capability_id":"temperatureMeasurement"}
PASSED
Running test "Temparture Alarm Reset handled" (2 of 2)
default_handlers:
init:
driverSwitched:
doConfigure:
infoChanged:
child_dispatchers:
default_handlers:
init:
[1]: OnOff
INFO || <ZigbeeDevice: 00000000-1111-2222-3333-000000000001 [0x0001] (Switch)> emitting event: {"component_id":"main","state":{"unit":"C","value":70},"attribute_id":"temperature","capability_id":"temperatureMeasurement"}
INFO || <ZigbeeDevice: 00000000-1111-2222-3333-000000000001 [0x0001] (Switch)> emitting event: {"component_id":"main","state":{"value":"heat"},"attribute_id":"temperatureAlarm","capability_id":"temperatureAlarm"}
INFO || <ZigbeeDevice: 00000000-1111-2222-3333-000000000001 [0x0001] (Switch)> emitting event: {"component_id":"main","state":{"unit":"C","value":65},"attribute_id":"temperature","capability_id":"temperatureMeasurement"}
INFO || <ZigbeeDevice: 00000000-1111-2222-3333-000000000001 [0x0001] (Switch)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x0001, dest_endpoint: 0x01, profile: 0x0104, cluster: Alarms >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x01, seqno: 0x00, ZCLCommandId: 0x00 >, < ResetAlarm || alarm_code: 0x86, cluster_identifier: SimpleMetering > > >
ZigbeeMessageRx:
Uint8: 0x00
AddressHeader:
src_addr: 0x0001
src_endpoint: 0x01
dest_addr: 0x0000
dest_endpoint: 0x01
profile: 0x0104
cluster: Alarms
Uint8: 0x00
Int8: 0
Uint16: 0x0006
ZCLMessageBody:
ZCLHeader:
frame_ctrl: 0x01
seqno: 0x00
ZCLCommandId: 0x00
ResetAlarm:
alarm_code: 0x86
but received:
ZigbeeMessageTx:
Uint16: 0x0000
AddressHeader:
src_addr: 0x0000
src_endpoint: 0x01
dest_addr: 0x0001
dest_endpoint: 0x01
profile: 0x0104
cluster: Alarms
ZCLMessageBody:
ZCLHeader:
frame_ctrl: 0x01
seqno: 0x00
ZCLCommandId: 0x00
ResetAlarm:
alarm_code: 0x86
FAILED
Passed 1 of 2 tests
What am I doing wrong in expect_send or in my function? I dont get it …
Thank you in advance!
