I got the smartapp tweaked with the delay and got the beta in GitHub.
I did that way and it certainly worked. I hadn’t thought of using a virtual switch as a inverted switch trigger. Thanks! However, I ended up continuing with the smartapp route because it is just awkward to make a simple room temp setpoint settings change. With my two stages of cooling fan speed it just was a little user unfriendly to the family to make a change.
