I have purchased the iReceiver WiFi Music receiver
and connected it using MediaRenderer (Connect). I have proceeded to try to make use of it with several different apps (Big Talker, Media Renderer Events, Mode Change and Notify With Sound) but cannot get it to work.
All I get is some slight clicking in the speaker (as if I plugged/unplugged in an aux cable) and then, at some random other time, either a dog barking or piano playing. These are not the sounds I have chose, nor are they playing immediately after a trigger.
What am I doing wrong? Clearly the speaker is connecting, as there is sound coming out of it.
What type of trigger are you using?
Are you able to go into your SmartApp list and click on the play icon to force it to play? I use the Speaker Notify with Sound and this is available
I have 4 different DLNA/Airplay receivers. (Lario, Veetop, AirMusic, iReceiver). All 4 work for Airplay and DLNA and are found by Smartthings using MediaRender Connect. I only got Lario, Veetop, AirMusic to play TTS messages though. The iReceiver never worked. I think there may be some compatibility issue.
