Could someone help me with this device?
I need a device handler to work, and test with Zemismart Button DH, OSRAM, EcoSmart, and many other, but none work.
The Raw description is:
01 0104 0401 00 04 0000 0001 0003 0500 03 0003 0019 0501
- manufacturer: HEIMAN
- model: RC-EM
I tried to modify this device handler but don’t works.
Summary
- Copyright 2019 SmartThings
- Licensed under the Apache License, Version 2.0 (the “License”); you may not use this file except
- in compliance with the License. You may obtain a copy of the License at:
http://www.apache.org/licenses/LICENSE-2.0
- Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
- on an “AS IS” BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
- for the specific language governing permissions and limitations under the License.
- Author: SRPOL
- Date: 2019-02-18
import groovy.json.JsonOutput
import physicalgraph.zigbee.zcl.DataType
metadata {
definition (name: “My modified Zigbee Multi Button”, namespace: “smartthings”, author: “SmartThings”, mcdSync: true, ocfDeviceType: “x.com.st.d.remotecontroller”) {
capability “Actuator”
capability “Battery”
capability “Button”
capability “Holdable Button”
capability “Configuration”
capability “Refresh”
capability “Sensor”
capability “Health Check”
fingerprint inClusters: "0000, 0001, 0003, 0007, 0020, 0B05", outClusters: "0003, 0006, 0019", manufacturer: "CentraLite", model:"3450-L", deviceJoinName: "Iris Remote Control", mnmn: "SmartThings", vid: "generic-4-button" //Iris KeyFob
fingerprint inClusters: "0000, 0001, 0003, 0007, 0020, 0B05", outClusters: "0003, 0006, 0019", manufacturer: "CentraLite", model:"3450-L2", deviceJoinName: "Iris Remote Control", mnmn: "SmartThings", vid: "generic-4-button" //Iris KeyFob
fingerprint profileId: "0104", inClusters: "0004", outClusters: "0000, 0001, 0003, 0004, 0005, 0B05", manufacturer: "HEIMAN", model: "SceneSwitch-EM-3.0", deviceJoinName: "HEIMAN Remote Control", vid: "generic-4-button" //HEIMAN Scene Keypad
//AduroSmart
fingerprint inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 0300, FCCC, 1000", outClusters: "0000, 0003, 0004, 0005, 0006, 0008, 0300, FCCC, 1000", manufacturer: "AduroSmart Eria", model: "ADUROLIGHT_CSC", deviceJoinName: "Eria Remote Control", mnmn: "SmartThings", vid: "generic-4-button" //Eria scene button switch V2.1
fingerprint inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 0300, FCCC, 1000", outClusters: "0000, 0003, 0004, 0005, 0006, 0008, 0300, FCCC, 1000", manufacturer: "ADUROLIGHT", model: "ADUROLIGHT_CSC", deviceJoinName: "Eria Remote Control", mnmn: "SmartThings", vid: "generic-4-button" //Eria scene button switch V2.0
fingerprint inClusters: "0000, 0003, 0008, FCCC, 1000", outClusters: "0003, 0004, 0006, 0008, FCCC, 1000", manufacturer: "ADUROLIGHT", model: "AduroLight_NCC", deviceJoinName: "Eria Remote Control", mnmn: "SmartThings", vid: "generic-4-button" //Eria dimming button switch V2.1 new model name
fingerprint inClusters: "0000, 0003, 0008, FCCC, 1000", outClusters: "0003, 0004, 0006, 0008, FCCC, 1000", manufacturer: "AduroSmart Eria", model: "Adurolight_NCC", deviceJoinName: "Eria Remote Control", mnmn: "SmartThings", vid: "generic-4-button" //Eria dimming button switch V2.1
fingerprint inClusters: "0000, 0003, 0008, FCCC, 1000", outClusters: "0003, 0004, 0006, 0008, FCCC, 1000", manufacturer: "ADUROLIGHT", model: "Adurolight_NCC", deviceJoinName: "Eria Remote Control", mnmn: "SmartThings", vid: "generic-4-button" //Eria dimming button switch V2.0
tiles {
standardTile("button", "device.button", width: 2, height: 2) {
state "default", label: "", icon: "st.unknown.zwave.remote-controller", backgroundColor: "#ffffff"
state "button 1 pushed", label: "pushed #1", icon: "st.unknown.zwave.remote-controller", backgroundColor: "#00A0DC"
valueTile("battery", "device.battery", decoration: "flat", inactiveLabel: false) {
state "battery", label:'${currentValue}% battery', unit:""
standardTile("refresh", "device.refresh", inactiveLabel: false, decoration: "flat") {
state "default", action:"refresh.refresh", icon:"st.secondary.refresh"
main (["button"])
details(["button", "battery", "refresh"])
def map = zigbee.getEvent(description)
def result = map ? map : parseAttrMessage(description)
if (result.name == “switch”) {
result = createEvent(descriptionText: “Wake up event came in”, isStateChange: true)
log.debug “Description {description} parsed to {result}”
return result
def parseAttrMessage(description) {
def descMap = zigbee.parseDescriptionAsMap(description)
def map = [:]
if (descMap?.clusterInt == zigbee.POWER_CONFIGURATION_CLUSTER && descMap.commandInt != 0x07 && descMap?.value) {
map = getBatteryPercentageResult(Integer.parseInt(descMap.value, 16))
} else if (isAduroSmartRemote()) {
map = parseAduroSmartButtonMessage(descMap)
} else if (descMap?.clusterInt == zigbee.ONOFF_CLUSTER && descMap.isClusterSpecific) {
map = getButtonEvent(descMap)
} else if (descMap?.clusterInt == 0x0005) {
def buttonNumber
buttonNumber = buttonMap[device.getDataValue(“model”)][descMap.data[2]]
log.debug "Number is ${buttonNumber}"
def descriptionText = getButtonName() + " ${buttonNumber} was pushed"
sendEventToChild(buttonNumber, createEvent(name: "button", value: "pushed", data: [buttonNumber: buttonNumber], descriptionText: descriptionText, isStateChange: true))
map = createEvent(name: "button", value: "pushed", data: [buttonNumber: buttonNumber], descriptionText: descriptionText, isStateChange: true)
map
def getButtonEvent(descMap) {
if (descMap.commandInt == 1) {
getButtonResult(“press”)
else if (descMap.commandInt == 0) {
def button = buttonMap[device.getDataValue(“model”)][descMap.sourceEndpoint]
getButtonResult(“release”, button)
def getButtonResult(buttonState, buttonNumber = 1) {
def event = [:]
if (buttonState == ‘release’) {
def timeDiff = now() - state.pressTime
if (timeDiff > 10000) {
return event
} else {
buttonState = timeDiff < holdTime ? “pushed” : “held”
def descriptionText = getButtonName() + " {buttonNumber} was {buttonState}"
event = createEvent(name: “button”, value: buttonState, data: [buttonNumber: buttonNumber], descriptionText: descriptionText, isStateChange: true)
sendEventToChild(buttonNumber, event)
return createEvent(descriptionText: descriptionText)
} else if (buttonState == ‘press’) {
state.pressTime = now()
return event
def sendEventToChild(buttonNumber, event) {
String childDni = “${device.deviceNetworkId}:$buttonNumber”
def child = childDevices.find { it.deviceNetworkId == childDni }
child?.sendEvent(event)
def getBatteryPercentageResult(rawValue) {
log.debug ‘Battery’
def volts = rawValue / 10
if (volts > 3.0 || volts == 0 || rawValue == 0xFF) {
} else {
def result = [
def minVolts = 2.1
def maxVolts = 3.0
def pct = (volts - minVolts) / (maxVolts - minVolts)
result.value = Math.min(100, (int)(pct * 100))
def linkText = getLinkText(device)
result.descriptionText = “{linkText} battery was {result.value}%”
createEvent(result)
def refresh() {
return zigbee.readAttribute(zigbee.POWER_CONFIGURATION_CLUSTER, batteryVoltage) +
zigbee.readAttribute(zigbee.ONOFF_CLUSTER, switchType)
zigbee.enrollResponse()
def ping() {
refresh()
def configure() {
def bindings = getModelBindings(device.getDataValue(“model”))
def cmds = zigbee.onOffConfig() +
zigbee.configureReporting(zigbee.POWER_CONFIGURATION_CLUSTER, batteryVoltage, DataType.UINT8, 30, 21600, 0x01) +
zigbee.enrollResponse() +
zigbee.readAttribute(zigbee.POWER_CONFIGURATION_CLUSTER, batteryVoltage) + bindings
if (isHeimanButton())
cmds += zigbee.writeAttribute(0x0000, 0x0012, DataType.BOOLEAN, 0x01) +
addHubToGroup(0x000F) + addHubToGroup(0x0010) + addHubToGroup(0x0011) + addHubToGroup(0x0012)
return cmds
def installed() {
sendEvent(name: “button”, value: “pushed”, isStateChange: true, displayed: false)
sendEvent(name: “supportedButtonValues”, value: supportedButtonValues.encodeAsJSON(), displayed: false)
initialize()
def updated() {
runIn(2, “initialize”, [overwrite: true])
def initialize() {
def numberOfButtons = modelNumberOfButtons[device.getDataValue(“model”)]
sendEvent(name: “numberOfButtons”, value: numberOfButtons, displayed: false)
sendEvent(name: “checkInterval”, value: 2 * 60 * 60 + 2 * 60, displayed: false, data: [protocol: “zigbee”, hubHardwareId: device.hub.hardwareID])
if(!childDevices) {
addChildButtons(numberOfButtons)
if(childDevices) {
def event
for(def endpoint : 1..device.currentValue("numberOfButtons")) {
event = createEvent(name: "button", value: "pushed", isStateChange: true)
sendEventToChild(endpoint, event)
private addChildButtons(numberOfButtons) {
for(def endpoint : 1…numberOfButtons) {
try {
String childDni = “${device.deviceNetworkId}:endpoint"
def componentLabel = getButtonName() + "{endpoint}”
componentLabel = device.displayName + " - ${endpoint}"
def child = addChildDevice("Child Button", childDni, device.getHub().getId(), [
completedSetup: true,
label : componentLabel,
isComponent : true,
componentName : "button$endpoint",
componentLabel: "Button $endpoint"
child.sendEvent(name: "supportedButtonValues", value: supportedButtonValues.encodeAsJSON(), displayed: false)
} catch(Exception e) {
log.debug "Exception: ${e}"
private getBatteryVoltage() { 0x0020 }
private getSwitchType() { 0x0000 }
private getHoldTime() { 1000 }
private getButtonMap() {[
“3450-L” : [
“01” : 4,
“02” : 3,
“03” : 1,
“04” : 2
“3450-L2” : [
“01” : 4,
“02” : 3,
“03” : 1,
“04” : 2
“SceneSwitch-EM-3.0” : [
“01” : 1,
“02” : 2,
“03” : 3,
“04” : 4
private getSupportedButtonValues() {
def values
if (device.getDataValue(“model”) == “SceneSwitch-EM-3.0”) {
values = [“pushed”]
values = [“pushed”]
} else {
values = [“pushed”, “held”]
return values
private getModelNumberOfButtons() {[
“3450-L” : 4,
“3450-L2” : 4,
“SceneSwitch-EM-3.0” : 4,
“ADUROLIGHT_CSC” : 4,
“AduroLight_NCC” : 4,
“Adurolight_NCC” : 4
private getModelBindings(model) {
def bindings =
for(def endpoint : 1…modelNumberOfButtons[model]) {
bindings += zigbee.addBinding(zigbee.ONOFF_CLUSTER, [“destEndpoint” : endpoint])
bindings += zigbee.addBinding(zigbee.LEVEL_CONTROL_CLUSTER, [“destEndpoint” : 2]) +
zigbee.addBinding(zigbee.LEVEL_CONTROL_CLUSTER, [“destEndpoint” : 3])
bindings
private getButtonName() {
def values = device.displayName.endsWith(’ 1’) ? “{device.displayName[0..-2]}" : "{device.displayName}”
return values
private Map parseAduroSmartButtonMessage(Map descMap){
def buttonState = “pushed”
def buttonNumber = 0
if (descMap.clusterInt == ADUROSMART_SPECIFIC_CLUSTER) {
def list2 = descMap.data
buttonNumber = (list2[1] as int) + 1
if (buttonNumber != 0) {
def childevent = createEvent(name: “button”, value: “pushed”, data: [buttonNumber: 1], isStateChange: true)
sendEventToChild(buttonNumber, childevent)
def descriptionText = “$device.displayName button $buttonNumber was $buttonState”
return createEvent(name: “button”, value: buttonState, data: [buttonNumber: buttonNumber], descriptionText: descriptionText, isStateChange: true)
} else {
return [:]
def isAduroSmartRemote(){
((device.getDataValue(“model”) == “Adurolight_NCC”) || (device.getDataValue(“model”) == “AduroLight_NCC”) || (device.getDataValue(“model”) == “ADUROLIGHT_CSC”))
def getADUROSMART_SPECIFIC_CLUSTER() {0xFCCC}
private getCLUSTER_GROUPS() { 0x0004 }
private List addHubToGroup(Integer groupAddr) {
[“st cmd 0x0000 0x01 {CLUSTER_GROUPS} 0x00 {{zigbee.swapEndianHex(zigbee.convertToHexString(groupAddr,4))} 00}”,
“delay 200”]
def isHeimanButton(){
