My experience to date has been that when I increase the set point and or change between heat and econoheat modes, the central area where temperature is displayed seems to update fairly quickly to that temperature sometimes without the device even turning on! Which I think is what is causing me to question things.
I did have it set to AF but I’ve now switched it to A.
So unless I’m doing something wrong I’ve tried various CoRE configurations and none have worked so far. I understand home automation is personal but thought if I could see what others where using I’d be able to repeat those in my configurations and work from there.
For instance, I have a CoRE setup that does the following :
Piston Mode - Simple
IF (Home is one of [Away, Holiday])
THEN (Using Living Room Underfloor Heating)
Set to Off
Trying this out does not work. I activated the Goodbye routine which changes the mode from Home to Away, checked the thermostat tile area and its events in the Recent
tab and nothing. The device was still set to Heat (red tile) and nothing appeared in recent events.
Likewise, I tried changing the THEN to Set Mode - Off ; nothing.
Additionally, i have tried the following :
IF (Living Room Underfloor Heating is less than 19.5)
THEN IF (mode is Home)
SET TO Heat
SET Heating Point to 20.5
Send SMS notification
Send Push notification
ELSE (Using Living Room Underfloor Heating)
Set to Cool
I originally inflated the is less than
to 30 as the temperature was already quite high in order to test this.
I got the SMS and Push for the first IF condition but nothing activated.
I know the device works I see my energy monitor shoot up when the UFH kicks in (without CoRE, just using set points)
I’m I doing something wrong here? It should be simple right, I’ve had other CoRE configurations running on other devices.
