I’m not sure I linked to the other thread properly - haven’t tried to do that before. When you get into the IDE you go to the Device Handler section now. Create a new handler (upper right). The modification is to change where is says:
capability “Sensor”
to:
capability “Sensor”
capability “Polling”
then “Save” and “Publish” “For Me”.
The next step after that is to go to your “My Devices” section in the IDE and create a new device and pick YOUR new device handler to use for it.
Then you can install the Pollster SmartApp and have it refresh the weather tile.
It is easier than it sounds but it does have a lot of steps.
If you bought a device that you could install or place outside then you just (may) need a screwdriver and virtual thermostat… Several motion sensors have a temperature sensor built into them, for example.
