@rey_rios@rplouff, @rusherracing, and others, here’s a device type I just created to replace the slider with low, medium, and high buttons and a tile showing the current speed setting:
It’s no longer listed on the Jasco site ( that’s the manufacturer, GE label), so I’m guessing it will be replaced by a zwave plus version pretty soon, a lot of manufacturers are doing that.
Meanwhile, Lowe’s will still let you order it online in the IRIS-branded box:
Or you can go for the Leviton fan control switch, although it costs more:
The Leviton is on the current official “works with SmartThings” list:
Any more details on this? Was just about to get one myself but not sure if I should hold off, like you say I can’t find it anywhere on their website except for the support section.
I have one it works flawlessly. Had for about three months now used with several smart apps including to cool house down mid day when nest is off. Works great
FYI, though it is hard to tell, Lowes DOES have these in-stock to parcel ship and at a great price. Ordered some other crap to hit the free shipping minimum, and poof it was at my door two days later. Works great.
Lowes around me never has these in-store. I was told they would have to custom order them direct from the manufacture.
I ended up getting 3 of them from here. http://www.discounthomeautomation.com/GE-Z-Wave-Ceiling-Fan-Wall-Switch-JA12730
Best bet is to email DHA to find out if they are in stock or not. Mine took about 3 weeks since they were on back order when I ordered them.
So far they have been working fine after I installed the custom fan controller device type.
Lucky for you, my house’s wiring was… interesting though I guess I can’t blame the GE device for that as once I had worked it out the wiring, it was a piece of cake.
NOTE OF WARNING: You MUST connect the NEUTRAL (white) wire, they will NOT work with just line, load and ground wires.
I am guessing that you are running into the same problem as I have at the moment and that is that it appears that this house is old enough (1980) and it only has the Ground, Load, and Line but no neutral wire, how did you work that out?
You will have to have an electrician “fish up” a neutral from somewhere else in the wall. If this is a US house built after 1940 and the wall switch is near an outlet, the outlet will almost surely have a neutral.
With a ceiling fan that has a light…if using the light but you don’t want the fan always turning on full speed…I assume the fan can be disabled via pull cord?
