I am looking for (I think) a hard wired 120V power sensor, or at least a device like a switch that also has power sensor capabilities.
I have an attic ventilator that I want to monitor to insure is running when the temperature rises. So I’m really looking for anything that senses power use so I can set a trigger based on current draw. Since the fans are typically hard wired, a hard wired device would be best. I know that I can convert from romex to a wired plug and then use a plug-in receptacle that has energy sensing, but it seems that a hard wired device added to the box would be easier.
TIA!
