Hard wire contact sensor
So I’ve been trying to figure out the best way to hard wire a garage contact sensor. I have a ENERWAVE Z-Wave Plus Dual Relay Module near the garage door and I’m not using the second relay.
Screenshot_20201122-150125_Amazon Shopping|233x500
Is there a way to use a wired magnetic contact sensor to turn on/off that relay? I doubt a standard contact could handle 110v to trigger it.
Tagging @johnconstantelo and @ogiewon in case they have any ideas, they both do a lot of maker type projects. :sunglasses:
You can get 110v contact sensors or we can in the UK. And they aren’t expensive.
Thanks, ill give that a try.
That did the trick. Was able to hard wire my contact sensor.
Glad to hear it was a success
