I’m sharing the finding of @nayelyz that was sent to Nir. With Nir approval. These are very interesting findings that an ordinary user can’t find:
The engineering team checked the drivers you have installed, and this is the feedback:
- We can see there’s a driver called “SonyBraviaTV” which reached nearly 10mb with just the 1 device
- We also see you have two different drivers for virtual devices, you should check if you can keep only one
- Also, the custom drivers from Mariano Colmenarejo (those that end with “MC” consume a little above 8mb)
- There are several drivers that are controling only one device, like:
- ZWaveSirenMc
- ZigbeeMultiGangSwitchYGv216
- VirtualCalendarMc
- SmartThingsMultipurposeSensorMc
- ZigbeeMotionSensor
- ZigbeeSwitchPowerMc
- ZigbeeAqaraWaterLeakSensorMc
- AqaraXiaomiTemperature15
- AplicacionesVirtualesMc — I remember Mariano mentioned he put the “virtual calendar” in this same driver. See here: (EDGE Driver-Mc): Aplicaciones Virtuales Mc (virtual Switch Mirror, Virtual Calendar and virtual Switch Board…) - #55 by Mariano_Colmenarejo
- ZigbeeMoistureSensorMc
- AplicacionesVirtualesMcSOS
I’m also adding that ZigbeeMoistureSensorMc include all devices of ZigbeeAqaraWaterLeakSensorMc. Therefore ZigbeeAqaraWaterLeakSensorMc can be unistall.
Also updating that Nir remove two unused Zigbee bulbs , this bring him back to driverMemoryLimitStatus OK (was Hard Limit). Problem solved for him…
