I am writing (trying) an app to connect ST to my Netatmo thermostat, using the weather station Netatmo Connect as a starting point.
My problem is that when I extract data elements from the http response, it always seems to be strings surrounded by square brackets, rather than numerical values.
Is there something basic/obvious that I am overlooking, or is more information needed about my code to explain the issue here?
Hi. Did you publish your Netatmo Thermostat device type somewhere? I bet that there are tons of fellow smartens (my humble self included) that would be delighted to be able to get their hands on the code
@TheBluProject this is still at very early stage, I have only completed POC getting set point, heating mode and current temperature, plus the all-important OAUTH connection. I will work on controlling setpoints, and other features before releasing it.
