- King Of Fans Zigbee Fan Controller
- To be used with Ceiling Fan Remote Controller Model MR101Z receiver by Chungear Industrial Co. Ltd
- at Home Depot Gardinier 52" Ceiling Fan, Universal Ceiling Fan/Light Premier Remote Model #99432
- Copyright 2017 Ranga Pedamallu, Stephan Hackett, Dale Coffing
- Contributing Authors:
Ranga Pedamallu; initial release and zigbee parsing mastermind!
Stephan Hackett; new composite (child) device type genius!
Dale Coffing; icons, multiAttribute fan, code maintenance flunky - Licensed under the Apache License, Version 2.0 (the “License”); you may not use this file except
- in compliance with the License. You may obtain a copy of the License at:
http://www.apache.org/licenses/LICENSE-2.0
- Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
- on an “AS IS” BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
- for the specific language governing permissions and limitations under the License.
def version() {“ver 0.2.170515”} //update as needed
def currVersions(child) { //Let’s user know if running the child versions that corresponds to this parent version
if(child==“fan”) {return “ver 0.2.170515”} //manually enter the version of the FAN child that matches the parent version above
if(child==“light”) {return “ver 0.2.170515a”} //manually enter the version of the LIGHT child that matches the parent version above
05/15 added GRN=OK RED=Update to version tile, changed parent tile version to fill empty space, shorten ver to increase font in tile
a- fixed line 225 -Light
05/05 modified Refresh text to Delete&Recreate
b- test new label Speed 1 (LOW) technique
a- evaluating new Speed 1,2,3,4 for ease of voice and look, it matches the fan speed bar icons instead of Lo, Med, Hi
05/04 Modified labels lowercase,Comfort Breeze™ , getFanName() to be longer names vs abbr
05/03 renamed LAMP to LIGHT in all instances to conform to ST standards
05/01 fixed bug when recreated child names didn’t use the new name but the original name; def createFanChild()
c- added TurningBreezeOff attributeState to match the Breeze icon
b- added CeilingFanParent in version, added new grey OFF icons
a- move Stephack latest changes;(one step child delete/create, etc) over in a copy/paste; change namespace
04/30 Moved refresh()Configure() from child creation method to initialize, added individual icons for fan child
04/29 new icons with fanspeed bar indication
e- added changes from Stephan to fix createChild error
d- go back to orginal code on line 182
c- createFanChild code added line 182 ChildDevice this part is the BUG that wont’ create all fanChild devices
b- details for childVer, added getChildVer() & def getChildVer()
a- attribute LchildVer, FchildVer
04/28 reverted back to 0426 and added new revision labeling to parent
04/26 label changes to read naturally, CAP light to match child speeds
04/25 label changes; Breeze color #008B64
0.2.1b parent on-off states sync with any child state for ActionTiles
04/19 added version tile to help in troubleshooting with users
metadata {
definition (name: “KOF Zigbee Fan Controller”, namespace: “dcoffing”, author: “Stephan Hackett, Ranga Pedamallu, Dale Coffing”) {
capability "Actuator"
capability "Configuration"
capability "Refresh"
capability "Switch"
capability "Light"
capability "Sensor"
capability “Polling”
//capability “Health Check”
command "lightOn"
command "lightOff"
command "lightLevel"
command "setFanSpeed"
attribute "fanMode", "string" //stores fanspeed
attribute "lightBrightness", "number" //stores brightness level
attribute "lastFanMode", "string" //used to restore previous fanmode
attribute "LchildVer", "string" //stores light child version
attribute "FchildVer", "string" //stores fan child version
attribute "LchildCurr", "string" //stores color of version check
attribute "FchildCurr", "string" //stores color of version check
fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 0202", outClusters: "0003, 0019", model: "HDC52EastwindFan"
preferences {
page(name: "childToRebuild", title: "This does not display on DTH preference page")
section("section") {
input(name: "refreshChildren", type: "bool", title: "Delete & Recreate all child devices?\n\nTypically used after modifying the parent device name " +
"above to give all child devices the new name.\n\nPLEASE NOTE: Child Devices must be removed from any smartApps BEFORE attempting this " +
"process or 'An unexpected error' occurs attempting to delete the child's.")
tiles(scale: 2) {
multiAttributeTile(name: "switch", type: "lighting", width: 6, height: 4) {
tileAttribute ("fanMode", key: "PRIMARY_CONTROL") {
attributeState "04", label:"HIGH", action:"off", icon:getIcon()+"fan4h.png", backgroundColor:"#79b821", nextState: "turningOff"
attributeState "03", label:"MED-HI", action:"off", icon:getIcon()+"fan3h.png", backgroundColor:"#79b821", nextState: "turningOff"
attributeState "02", label:"MED", action:"off", icon:getIcon()+"fan2h.png", backgroundColor:"#79b821", nextState: "turningOff"
attributeState "01", label:"LOW", action:"off", icon:getIcon()+"fan1h.png", backgroundColor:"#79b821", nextState: "turningOff"
attributeState "06", label:"BREEZE", action:"off", icon:getIcon()+"breeze4h_blk.png", backgroundColor:"#008B64", nextState: "turningBreezeOff"
attributeState "00", label:"FAN OFF", action:"on", icon:getIcon()+"fan00h_grey.png", backgroundColor:"#ffffff", nextState: "turningOn"
attributeState "turningOn", action:"on", label:"TURNING ON", icon:getIcon()+"fan0h.png", backgroundColor:"#2179b8", nextState: "turningOn"
attributeState "turningOff", action:"off", label:"TURNING OFF", icon:getIcon()+"fan0h_grey.png", backgroundColor:"#2179b8", nextState: "turningOff"
attributeState "turningBreezeOff", action:"off", label:"TURNING OFF", icon:getIcon()+"breeze4h_teal.png", backgroundColor:"#2179b8", nextState: "turningOff"
tileAttribute ("lightBrightness", key: "SLIDER_CONTROL") {
attributeState "lightBrightness", action:"lightLevel"
standardTile("refresh", "refresh", decoration: "flat", width: 2, height: 3) {
state "default", label:"", action:"refresh.refresh", icon:"st.secondary.refresh"
valueTile("version", "version", width:4, height:1) {
state "version", label:"Ceiling Fan Parent\n"+ version()
valueTile("FchildVer", "FchildVer", width:3, height:1) {
state "FchildVer", label: "Fan Child "+'${currentValue}'+"\nGRN=OK RED=Update"
valueTile("LchildVer", "LchildVer", width:3, height:1) {
state "LchildVer", label:"Light Child "+'${currentValue}'+"\nGRN=OK RED=Update"
valueTile("FchildCurr", "FchildCurr", width:1, height:1) {
state "FchildCurr", label: "", backgroundColors:[
[value: 1, color: "#FF0000"],
[value: 2, color: "#3EAE40"]
valueTile("LchildCurr", "LchildCurr", width:1, height:1) {
state "LchildCurr", label:"", backgroundColors:[
//childDeviceTiles("fanSpeeds", height: 1, width: 6)
childDeviceTile("fanMode1", "fanMode1", height: 2, width: 2)
childDeviceTile("fanMode2", "fanMode2", height: 2, width: 2)
childDeviceTile("fanMode3", "fanMode3", height: 2, width: 2)
childDeviceTile("fanMode4", "fanMode4", height: 2, width: 2)
childDeviceTile("fanMode6", "fanMode6", height: 2, width: 2)
childDeviceTile("fanLight", "fanLight", height: 2, width: 2)
main(["switch"])
details(["switch", "fanLight", "fanMode1", "fanMode2", "fanMode6", "fanMode3", "fanMode4", "refresh", "FchildVer", "FchildCurr", "LchildVer", "LchildCurr", "version"])
//log.debug "Parse description $description"
def event = zigbee.getEvent(description)
if (event) {
log.info "Light event detected on controller: ${event}"
def childDevice = getChildDevices()?.find { //find light child device
it.device.deviceNetworkId == “${device.deviceNetworkId}-Light”
childDevice.sendEvent(event) //send light events to light child device and update lightBrightness attribute
if(event.value != “on” && event.value != “off”) sendEvent(name: “lightBrightness”, value: event.value)
else {
log.info "Fan event detected on controller"
def map = [:]
if (description?.startsWith(“read attr -”)) {
def descMap = zigbee.parseDescriptionAsMap(description)
if (descMap.cluster == “0202” && descMap.attrId == “0000”) { // Fan Control Cluster Attribute Read Response
map.name = "fanMode"
map.value = descMap.value
fanSync(descMap.value)
} // End of Read Attribute Response
def result = null
if (map) {
result = createEvent(map)
log.debug "Parse returned $map"
return result
def getIcon() {
return “https://cdn.rawgit.com/dcoffing/KOF-CeilingFan/master/resources/images/”
def getFanName() {
“00”:“Off”,
“01”:“Low”,
“02”:“Med”,
“03”:“Med-Hi”,
“04”:“High”,
“05”:“Off”,
“06”:“Comfort Breeze™”,
“07”:“Light”
def getFanNameAbbr() {
“00”:“Off”,
“01”:“Low”,
“02”:“Med”,
“03”:“Med-Hi”,
“04”:“High”,
“05”:“Off”,
“06”:“Breeze™”,
“07”:“Light”
def installed() {
initialize()
def updated() {
if(state.oldLabel != device.label) {updateChildLabel()}
initialize()
def initialize() {
log.info "Initializing"
if(refreshChildren) {
deleteChildren()
device.updateSetting(“refreshChildren”, false)
else {
createFanChild()
createLightChild()
response(refresh() + configure())
def updateChildLabel() {
log.info "UPDATE LABEL"
for(i in 1…6) {
it.device.deviceNetworkId == “${device.deviceNetworkId}-0${i}”
if (childDevice && i != 5) {childDevice.label = “${device.displayName} ${getFanName()[“0${i}”]}”} // rename with new label
def childDeviceL = getChildDevices()?.find {
it.device.deviceNetworkId == "${device.deviceNetworkId}-Light"
if (childDeviceL) {childDeviceL.label = "${device.displayName}-Light"} // rename with new label
def createFanChild() {
state.oldLabel = device.label //save the label for reference if it ever changes
for(i in 1…6) {
if (!childDevice && i != 5) {
childDevice = addChildDevice(“KOF Zigbee Fan Controller - Fan Speed Child Device”, “${device.deviceNetworkId}-0${i}”, null,[completedSetup: true,
label: “${device.displayName} ${getFanName()[“0${i}”]}”, isComponent: true, componentName: “fanMode${i}”,
componentLabel: “${getFanName()[“0${i}”]}”, “data”:[“speedVal”:“0${i}”,“parent version”:version()]])
log.info “Creating child fan mode ${childDevice}”
else {
log.info “Child already exists”
def createLightChild() {
if (!childDevice) {
childDevice = addChildDevice(“KOF Zigbee Fan Controller - Light Child Device”, “${device.deviceNetworkId}-Light”, null,[completedSetup: true,
label: “${device.displayName} Light”, isComponent: false, componentName: “fanLight”,
componentLabel: “Light”, “data”:[“parent version”:version()]])
log.info “Creating child light ${childDevice}”
else {
def deleteChildren() {
def children = getChildDevices()
children.each {child->
deleteChildDevice(child.deviceNetworkId)
log.info “Deleting children”
def configure() {
log.info “Configuring Reporting and Bindings.“
def cmd =
//Set long poll interval
"raw 0x0020 {11 00 02 02 00 00 00}”, “delay 100”,
“send 0x${device.deviceNetworkId} 1 1”, “delay 100”,
//Bindings for Fan Control
"zdo bind 0x${device.deviceNetworkId} 1 1 0x006 {${device.zigbeeId}} {}”, “delay 100”,
“zdo bind 0x${device.deviceNetworkId} 1 1 0x008 {${device.zigbeeId}} {}”, “delay 100”,
“zdo bind 0x${device.deviceNetworkId} 1 1 0x202 {${device.zigbeeId}} {}”, “delay 100”,
//Fan Control - Configure Report
"zcl global send-me-a-report 0x006 0 0x10 1 300 {}", “delay 100”,
“zcl global send-me-a-report 0x008 0 0x20 1 300 {}”, “delay 100”,
“zcl global send-me-a-report 0x202 0 0x30 1 300 {}”, “delay 100”,
//Update values
"st rattr 0x${device.deviceNetworkId} 1 0x006 0", “delay 100”,
“st rattr 0x${device.deviceNetworkId} 1 0x008 0”, “delay 100”,
“st rattr 0x${device.deviceNetworkId} 1 0x202 0”, “delay 100”,
"raw 0x0020 {11 00 02 1C 00 00 00}", “delay 100”,
return cmd + refresh()
def on() {
log.info “Resuming Previous Fan Speed"
def lastFan = device.currentValue(“lastFanMode”) //resumes previous fanspeed
return setFanSpeed(”$lastFan")
def off() {
def fanNow = device.currentValue(“fanMode”) //save fanspeed before turning off so it can be resumed when turned back on
if(fanNow != “00”) sendEvent(“name”:“lastFanMode”, “value”:fanNow) //do not save lastfanmode if fan is already off
def cmds=[
“st wattr 0x${device.deviceNetworkId} 1 0x202 0 0x30 {00}”
log.info "Turning fan Off"
return cmds
def lightOn() {
log.info "Turning Light On"
zigbee.on()
def lightOff() {
log.info "Turning Light Off"
zigbee.off()
def lightLevel(val) {
log.info "Adjusting Light Brightness"
zigbee.setLevel(val) + (val?.toInteger() > 0 ? zigbee.on() : [])
def setFanSpeed(speed) {
def cmds=[
“st wattr 0x${device.deviceNetworkId} 1 0x202 0 0x30 {${speed}}”
log.info "Adjusting Fan Speed to "+ getFanName()[speed]
return cmds
def fanSync(whichFan) {
def childSpeedVal = child.getDataValue(‘speedVal’)
if(childSpeedVal == whichFan) { //send ON event to corresponding child fan
// child.sendEvent(name:“switch”,value:“on”)
child.sendEvent(name:“fanSpeed”, value:“on${childSpeedVal}”) //custom icon code
sendEvent(name:“switch”,value:“on”) //send ON event to Fan Parent
else {
if(childSpeedVal!=null){
//log.info childSpeedVal
// child.sendEvent(name:“switch”,value:“off”) //send OFF event to all other child fans
child.sendEvent(name:“fanSpeed”, value:“off${childSpeedVal}”) //custom icon code
if(whichFan == “00”) sendEvent(name:“switch”,value:“off”) //send OFF event to Fan Parent
def ping() {
return zigbee.onOffRefresh()
def refresh() {
getChildVer()
zigbee.onOffRefresh() + zigbee.levelRefresh() + zigbee.readAttribute(0x0202, 0x0000)
def getChildVer() {
def FchildDevice = getChildDevices()?.find {
it.device.deviceNetworkId == “${device.deviceNetworkId}-01”
if(FchildDevice){ //find a fan device, 1. get version info and store in FchildVer, 2. check child version is current and set color accordingly
sendEvent(name:“FchildVer”, value: FchildDevice.version())
FchildDevice.version() != currVersions(“fan”)?sendEvent(name:“FchildCurr”, value: 1):sendEvent(name:“FchildCurr”, value: 2)
def LchildDevice = getChildDevices()?.find {
if(LchildDevice) { //find the light device, get version info and store in LchildVer
sendEvent(name:"LchildVer", value: LchildDevice.version())
LchildDevice.version() != currVersions("light")?sendEvent(name:"LchildCurr", value: 1):sendEvent(name:"LchildCurr", value: 2)
