Just to confirm - changing to a new GS smartApp worked fine for me, i.e. old streams in GS itself were not affected and it just added the new component/stream as I had wanted.
I think I went through the guide ok but I get no components showing, I am in the UK if that causes any problems.
Any idea what I can check to get this working?
well just typical, there are components now, hours after I set it all up
yvesracine,
Thank you for posting this. I have been modifying the existing code to collect all of this data and doing it rouge. I’m glad I did as it forced me to learn about what’s going on behind the scenes. I ran into a wall when trying to figure out how to pass the enum variables. So I broke down and searched this post for ecobee support… appreciate the work
Nick
Thanks for putting this together!
Hi @Nsiegfried,
Please note that the groveStream’s ecobee support is done with My Ecobee device which is the most comprehensive ecobee integration with SmartThings.
Regards.
I have everything setup using your code at the bottom of the tutorial. I seem to be using a lot of data. I have only bee using it about a week and im very close to the 5MB monthly allowance. Any guidance on how to slow this down ?
Dear all
I have reached my maximum 5 mb of data in Grovestream. I have a lot of sensors that report different types of data. One sensor (power plug) reports data every 5-10 seconds.
I have read the entire thread but have not been able to find any solution to reduce my data usage - maybe someine in here could help me?
My grovestreams setup is as follows:
* SmartThings example Code for GroveStreams
* A full "how to" guide for this example can be found at
* https://www.grovestreams.com/developers/getting_started_smartthings.html
* Copyright 2015 Jason Steele
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
definition(
namespace: "JasonBSteele",
author: "Jason Steele",
description: "Log to GroveStreams",
category: "My Apps",
iconUrl: "https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience.png",
iconX2Url: "https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience@2x.png",
iconX3Url: "https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience@2x.png")
preferences {
section("Log devices...") {
input "temperatures", "capability.temperatureMeasurement", title: "Temperatures", required:false, multiple: true
input "illuminance", "capability.illuminanceMeasurement", title: "Illuminance", required:false, multiple: true
input "ultravioletIndex", "capability.ultravioletIndex", title: "ultravioletindex", required:false, multiple: true
input "humidities", "capability.relativeHumidityMeasurement", title: "Humidities", required: false, multiple: true
input "contacts", "capability.contactSensor", title: "Doors open/close", required: false, multiple: true
input "accelerations", "capability.accelerationSensor", title: "Accelerations", required: false, multiple: true
input "motions", "capability.motionSensor", title: "Motions", required: false, multiple: true
input "presence", "capability.presenceSensor", title: "Presence", required: false, multiple: true
input "switches", "capability.switch", title: "Switches", required: false, multiple: true
input "waterSensors", "capability.waterSensor", title: "Water sensors", required: false, multiple: true
input "batteries", "capability.battery", title: "Batteries", required:false, multiple: true
input "powers", "capability.powerMeter", title: "Power Meters", required:false, multiple: true
input "energies", "capability.energyMeter", title: "Energy Meters", required:false, multiple: true
section ("GroveStreams Feed PUT API key...") {
input "apiKey", "text", title: "API key"
def installed() {
initialize()
def updated() {
unsubscribe()
initialize()
def initialize() {
subscribe(temperatures, "temperature", handleTemperatureEvent)
subscribe(illuminance, "illuminance", handleIlluminanceEvent)
subscribe(ultravioletIndex, "ultravioletIndex", handleultravioletIndexEvent)
subscribe(waterSensors, "water", handleWaterEvent)
subscribe(humidities, "humidity", handleHumidityEvent)
subscribe(contacts, "contact", handleContactEvent)
subscribe(accelerations, "acceleration", handleAccelerationEvent)
subscribe(motions, "motion", handleMotionEvent)
subscribe(presence, "presence", handlePresenceEvent)
subscribe(switches, "switch", handleSwitchEvent)
subscribe(batteries, "battery", handleBatteryEvent)
subscribe(powers, "power", handlePowerEvent)
subscribe(energies, "energy", handleEnergyEvent)
def handleTemperatureEvent(evt) {
sendValue(evt) { it.toString() }
def handleIlluminanceEvent(evt) {
def handleultravioletIndexEvent(evt) {
def handleWaterEvent(evt) {
sendValue(evt) { it == "wet" ? "true" : "false" }
def handleHumidityEvent(evt) {
def handleContactEvent(evt) {
sendValue(evt) { it == "open" ? "true" : "false" }
def handleAccelerationEvent(evt) {
sendValue(evt) { it == "active" ? "true" : "false" }
def handleMotionEvent(evt) {
def handlePresenceEvent(evt) {
sendValue(evt) { it == "present" ? "true" : "false" }
def handleSwitchEvent(evt) {
sendValue(evt) { it == "on" ? "true" : "false" }
def handleBatteryEvent(evt) {
def handlePowerEvent(evt) {
def handleEnergyEvent(evt) {
private sendValue(evt, Closure convert) {
def compId = URLEncoder.encode(evt.displayName.trim())
def streamId = evt.name
def value = convert(evt.value)
log.debug "Logging to GroveStreams ${compId}, ${streamId} = ${value}"
def url = "https://grovestreams.com/api/feed?api_key=${apiKey}&compId=${compId}&${streamId}=${value}"
//Make the actual device the origin of the message to avoid exceeding 12 calls within 2 minutes rule:
//http://forum.grovestreams.com/topic/155/10-second-feed-put-limit-algorithm-change/
def header = ["X-Forwarded-For": evt.deviceId]
def putParams = [
uri: url,
header: header,
body: []]
httpPut(putParams) { response ->
if (response.status != 200 ) {
log.debug "GroveStreams logging failed, status = ${response.status}"
you would have to switch to a device handler that doesn’t report so often. The Centralite plug is crazy-noisy at default. Maybe there is a custom handler for it.
I found it easier to use a different physical device with better defaults, or use custom DH with customizable report rates, e.g. Zooz Zen15.
