Good morning, anyone that have come across the Grohe Water guard, it is a great water stopper for the house with flow, temp and smart control (at least it was smart once). It seems like Grohe has stopped producing and supporting it and now the app is not working other than giving me alarms. So if i am running the sprinklers, it will read it as a leak and it will close the main valve and i have no water to the house, before i could just turn it on with the app where ever i was in the world, but now it iis not working anymore, so i have manually press the opening off the valve. When running the sprinklers i always set it in sprinkler mode and the app confirms that it has sent it to the unit, but this is not correct. So if anyone has come across this - would it be possible to integrate it to the SmartThings hub instead ?
it looks like it’s a Wi-Fi device and likely communicated with a cloud service that Grohe hosted somewhere and that the app communicated with. Unless there is a documented API that the device exposes on the local LAN, it’s unlikely that there would be a way to integrate it with ST.
This is correct, i am calling them (Grohe) again this morning - there is an API that i believe the guys at Homey use. I am not into programming so i do not understand all of this, but at Github, there is something called FlorianSW/Grohe-ondus.api.java
That is still dependent on their ONDUS cloud. So, we need to understand whether their cloud is still operative and/or are their APIs exposed by the device on the local LAN.
That’s frustrating, especially when the app keeps shutting off your water during sprinkler use. It would be great if the Grohe Water Guard could integrate with SmartThings, but it depends on whether the device supports a compatible connection or community integration.
