Squidward
(Jordon)
February 24, 2017, 4:43am
2
I used this handler instead. Adds a switch to it so can connect to google home. Then made an ifttt trigger that opens garage when I say open garage door. I use ifttt because with the switch it only open or closes when you tell it to turn it on (open) or turn it off (close)
I’ve modified the ST default “Z-Wave Garage Door Opener” to better work with the “doors & locks” module. As far as I know, this would only be useful for the linear GD00Z device (and variants including the Iris opener.) This will allow you to select your garage door device as both the “open/close sensor” and the “garage door opener relay.” At that point, from within the “doors & locks” module, you can use “open and close it remotely” (and perhaps the other sub-modules that open/close the door.)
All this does is to add the “relay switch” and “momentary” capabilities to the type, stubs on()/off(), and defines push() to either open or close the door (depending on it’s current state.) It’s not a perfect implementation, as the “doors & locks” module might show the door as being “stopped” wh…
I hope this helps
