Gocontrol door sensor always open
exact same gocontrol contact sensor and exact same issue. the masquerade by phil30 works. havent experienced random open, but will update if it does. so far it is working fine for me.
UPDATE: random open status like previous poster said. I believe this only happens if you connect the sensors with your existing wire contacts. All my contact sensors that are using the wire connection are having issues, the others that are not using the wires are fine.
Hi, everyone.
Sorry for the delay, I don’t know why this happened, it could be the IP address being incorrect.
Is there someone that still has the issue and could share the driver logs, please?
I just started this topic since apparently I didn’t search well enough before posting. As noted above, the Masquerade driver does work but only for one set of contacts. I’m looking for a solution that will also integrate the set of external contacts as originally intended by the manufacturer.
Thank you
A post was merged into an existing topic: Nortek Linear GoControl Z-Wave Multisensor ST Edge Driver help needed (WADWAZ-1)
I have this same problem with my GoControl sensors. I use 6 of them for my hard wired windows, so having them all report “open” starting a month ago is extremely annoying, and very disappointing. Was there an Edge driver switch 1 month ago? Sorry for the ignorance…I haven’t been on the community in a long time because everything was working ok for the past year.
My thanks to @valkokir for correcting me on the model number. I have updated this post.
If someone who has this problem could temporarily assign the sensor to Mariano’s Z wave configuration driver and let us know both the parameter values and the association groups, that might help, Note that you will have to wake the device up to get the information, so you will also need the user manual.
@nayelyz
Tried it with partial success. It reports the association groups immediately on waking up, but when I tried to use the parameter scan the “waiting for device response” message cleared but no data appeared. I’ll try to work with Mariano in the other thread tomorrow when I can (maybe) get CLI logging up while I do it.
Initial device add with all switches closed:
2023-03-09T13:25:07.276956935+00:00 WARN Z-Wave Device Config Mc  Unexpected filesystem lookup for capability legendabsolute60149.wakeUpValue
2023-03-09T13:25:07.316680519+00:00 TRACE Z-Wave Device Config Mc  Setup driver zwave_thing with lifecycle handlers:
DeviceLifecycleDispatcher: zwave_thing
  default_handlers:
    doConfigure:
    added:
    driverSwitched:
    infoChanged:
    init:
  child_dispatchers:
2023-03-09T13:25:07.321047269+00:00 TRACE Z-Wave Device Config Mc  Setup driver zwave_thing with Capability handlers:
CapabilityCommandDispatcher: zwave_thing
  default_handlers:
    legendabsolute60149.parameterend:
      setParameterEnd
    refresh:
      refresh
    legendabsolute60149.groupNumber:
      setGroupNumber
    legendabsolute60149.groupNumberEnd:
      setGroupNumberEnd
    legendabsolute60149.groupNumberStart:
      setGroupNumberStart
    legendabsolute60149.deviceParameter:
      setDeviceParameter
    legendabsolute60149.deviceAssociationType:
      setDeviceAssociationType
    legendabsolute60149.groupCommandOption:
      setGroupCommandOption
    legendabsolute60149.parameterSize:
      setParameterSize
    legendabsolute60149.parameterStart:
      setParameterStart
    legendabsolute60149.commandConfig1:
      setCommandConfig
    legendabsolute60149.nodeEndPoint:
      setNodeEndPoint
    legendabsolute60149.nodeToWriteHex:
      setNodeToWrite
    legendabsolute60149.parameterValue:
      setParameterValue
    legendabsolute60149.actionbutton2:
      push
  child_dispatchers:
2023-03-09T13:25:07.321778310+00:00 TRACE Z-Wave Device Config Mc  Setup driver zwave_thing with Z-Wave handlers:
ZwaveDispatcher: zwave_thing
  default_handlers:
    CONFIGURATION:
      REPORT
    ASSOCIATION:
      REPORT
    VERSION:
      REPORT
    MULTI_CHANNEL_ASSOCIATION:
      REPORT
  child_dispatchers:
2023-03-09T13:25:07.331929685+00:00 TRACE Z-Wave Device Config Mc  Z-Wave Device: 1a8b55d9-9eff-4581-a8b0-4b8c30ee2696
Manufacturer: 0x014F Product Type: 0x2001 Product ID: 0x0102
        [0]: NOTIFICATION, ASSOCIATION, BATTERY, MANUFACTURER_SPECIFIC, SENSOR_BINARY, VERSION, WAKE_UP
2023-03-09T13:25:07.332652602+00:00 TRACE Z-Wave Device Config Mc  Received event with handler _resync
2023-03-09T13:25:07.333304435+00:00 TRACE Z-Wave Device Config Mc  Received event with handler environment_info
2023-03-09T13:25:07.344525769+00:00 TRACE Z-Wave Device Config Mc  Found DeviceLifecycleDispatcher handler in zwave_thing
2023-03-09T13:25:07.346142269+00:00 TRACE Z-Wave Device Config Mc  Z-Wave command(286ca378) queued for radio transmission: CC:Version, CID:0x11
2023-03-09T13:25:07.346879269+00:00 PRINT Z-Wave Device Config Mc  <<<<<<<< device:get_field(firmVersion)
2023-03-09T13:25:07.347524352+00:00 INFO Z-Wave Device Config Mc  <ZwaveDevice: 1a8b55d9-9eff-4581-a8b0-4b8c30ee2696 [02] (Nortek Open/Closed Sensor)> sending Z-Wave command: {args={}, cmd_class="VERSION", cmd_id="GET", dst_channels={}, encap="AUTO", payload="", src_channel=0, version=1}
2023-03-09T13:25:07.358553019+00:00 TRACE Z-Wave Device Config Mc  Z-Wave command(45164e7a) queued for radio transmission: CC:Version, CID:0x11
2023-03-09T13:25:07.359063852+00:00 DEBUG Z-Wave Device Config Mc  Nortek Open/Closed Sensor device thread event handled
2023-03-09T13:25:07.359842810+00:00 TRACE Z-Wave Device Config Mc  Received event with handler environment_info
2023-03-09T13:25:07.360666227+00:00 DEBUG Z-Wave Device Config Mc  Z-Wave hub node ID environment changed.
2023-03-09T13:25:07.361284769+00:00 TRACE Z-Wave Device Config Mc  Received event with handler device_lifecycle
2023-03-09T13:25:07.361893602+00:00 INFO Z-Wave Device Config Mc  <ZwaveDevice: 1a8b55d9-9eff-4581-a8b0-4b8c30ee2696 [02] (Nortek Open/Closed Sensor)> received lifecycle event: added
2023-03-09T13:25:07.362896394+00:00 TRACE Z-Wave Device Config Mc  Found DeviceLifecycleDispatcher handler in zwave_thing
2023-03-09T13:25:07.363528310+00:00 PRINT Z-Wave Device Config Mc  <<<<<<<< device:get_field(firmVersion)
2023-03-09T13:25:07.374054102+00:00 INFO Z-Wave Device Config Mc  <ZwaveDevice: 1a8b55d9-9eff-4581-a8b0-4b8c30ee2696 [02] (Nortek Open/Closed Sensor)> sending Z-Wave command: {args={}, cmd_class="VERSION", cmd_id="GET", dst_channels={}, encap="AUTO", payload="", src_channel=0, version=1}
2023-03-09T13:25:07.374865727+00:00 DEBUG Z-Wave Device Config Mc  Nortek Open/Closed Sensor device thread event handled
2023-03-09T13:25:07.375567810+00:00 TRACE Z-Wave Device Config Mc  Received event with handler device_lifecycle
2023-03-09T13:25:07.376184685+00:00 INFO Z-Wave Device Config Mc  <ZwaveDevice: 1a8b55d9-9eff-4581-a8b0-4b8c30ee2696 [02] (Nortek Open/Closed Sensor)> received lifecycle event: driverSwitched
2023-03-09T13:25:07.377164102+00:00 TRACE Z-Wave Device Config Mc  Found DeviceLifecycleDispatcher handler in zwave_thing
2023-03-09T13:25:07.378078560+00:00 DEBUG Z-Wave Device Config Mc  Nortek Open/Closed Sensor device thread event handled
2023-03-09T13:25:07.384042060+00:00 DEBUG Z-Wave Device Config Mc  Nortek Open/Closed Sensor device thread event handled
2023-03-09T13:25:07.608166394+00:00 TRACE Z-Wave Device Config Mc  Received event with handler device_lifecycle
2023-03-09T13:25:07.614499936+00:00 INFO Z-Wave Device Config Mc  <ZwaveDevice: 1a8b55d9-9eff-4581-a8b0-4b8c30ee2696 [02] (Nortek Open/Closed Sensor)> received lifecycle event: infoChanged
2023-03-09T13:25:07.616712977+00:00 TRACE Z-Wave Device Config Mc  Found DeviceLifecycleDispatcher handler in zwave_thing
2023-03-09T13:25:07.617377602+00:00 PRINT Z-Wave Device Config Mc  device.preferences[infoChanged]=             preferences:    version
2023-03-09T13:25:07.617996936+00:00 PRINT Z-Wave Device Config Mc  << Preference changed name:  version old value:     nil      new value:
2023-03-09T13:25:07.618661852+00:00 PRINT Z-Wave Device Config Mc  device.preferences[infoChanged]=     Info    preferences:    changeConfigProfile
2023-03-09T13:25:07.619277602+00:00 PRINT Z-Wave Device Config Mc  << Preference changed name:  changeConfigProfile    old value:       nil     new value:      Info
2023-03-09T13:25:07.626439102+00:00 DEBUG Z-Wave Device Config Mc  Nortek Open/Closed Sensor device thread event handled
2023-03-09T13:25:07.629420311+00:00 DEBUG Z-Wave Device Config Mc  Nortek Open/Closed Sensor device thread event handled
2023-03-09T13:25:08.641652686+00:00 TRACE Z-Wave Device Config Mc  Z-Wave command(1240ecb6) queued for radio transmission: CC:Version, CID:0x11
2023-03-09T13:25:08.642345936+00:00 INFO Z-Wave Device Config Mc  <ZwaveDevice: 1a8b55d9-9eff-4581-a8b0-4b8c30ee2696 [02] (Nortek Open/Closed Sensor)> sending Z-Wave command: {args={}, cmd_class="VERSION", cmd_id="GET", dst_channels={}, encap="AUTO", payload="", src_channel=0, version=1}
2023-03-09T13:25:08.647889311+00:00 TRACE Z-Wave Device Config Mc  Z-Wave command(4572680c) queued for radio transmission: CC:Version, CID:0x11
2023-03-09T13:25:08.648378103+00:00 PRINT Z-Wave Device Config Mc  <<<<<<<< device:get_field(firmVersion)
2023-03-09T13:25:08.649006644+00:00 INFO Z-Wave Device Config Mc  <ZwaveDevice: 1a8b55d9-9eff-4581-a8b0-4b8c30ee2696 [02] (Nortek Open/Closed Sensor)> sending Z-Wave command: {args={}, cmd_class="VERSION", cmd_id="GET", dst_channels={}, encap="AUTO", payload="", src_channel=0, version=1}
2023-03-09T13:25:08.653549978+00:00 DEBUG Z-Wave Device Config Mc  Nortek Open/Closed Sensor device thread event handled
2023-03-09T13:25:11.756965771+00:00 TRACE Z-Wave Device Config Mc  Z-Wave command(286ca378) transmit status: TRANSMIT_COMPLETE_NO_ACK
2023-03-09T13:25:16.176937940+00:00 TRACE Z-Wave Device Config Mc  Z-Wave command(45164e7a) transmit status: TRANSMIT_COMPLETE_NO_ACK
2023-03-09T13:25:20.546989317+00:00 TRACE Z-Wave Device Config Mc  Z-Wave command(1240ecb6) transmit status: TRANSMIT_COMPLETE_NO_ACK
2023-03-09T13:25:24.826947027+00:00 TRACE Z-Wave Device Config Mc  Z-Wave command(4572680c) transmit status: TRANSMIT_COMPLETE_NO_ACK
Magnetic Contact Open
2023-03-09T13:27:04.437966700+00:00 TRACE Z-Wave Device Config Mc  Received event with handler unnamed
2023-03-09T13:27:04.439856325+00:00 INFO Z-Wave Device Config Mc  <ZwaveDevice: 1a8b55d9-9eff-4581-a8b0-4b8c30ee2696 [02] (Nortek Open/Closed Sensor)> received Z-Wave command: {args={value=255}, cmd_class="BASIC", cmd_id="SET", dst_channels={}, encap="NONE", payload="\xFF", src_channel=0, version=1}
2023-03-09T13:27:04.446349158+00:00 DEBUG Z-Wave Device Config Mc  Nortek Open/Closed Sensor device thread event handled
2023-03-09T13:27:04.446817033+00:00 TRACE Z-Wave Device Config Mc  Received event with handler unnamed
2023-03-09T13:27:04.447434241+00:00 INFO Z-Wave Device Config Mc  <ZwaveDevice: 1a8b55d9-9eff-4581-a8b0-4b8c30ee2696 [02] (Nortek Open/Closed Sensor)> received Z-Wave command: {args={alarm_level=255, alarm_type=7, event="INTRUSION", event_parameter="", notification_status="ON", notification_type="HOME_SECURITY", v1_alarm_level=255, v1_alarm_type=7, z_wave_alarm_event="INTRUSION", z_wave_alarm_status="ON", z_wave_alarm_type="BURGLAR", zensor_net_source_node_id=0}, cmd_class="NOTIFICATION", cmd_id="REPORT", dst_channels={}, encap="NONE", payload="\x07\xFF\x00\xFF\x07\x02\x00\x00", src_channel=0, version=3}
2023-03-09T13:27:04.448600033+00:00 DEBUG Z-Wave Device Config Mc  Nortek Open/Closed Sensor device thread event handled
Magnetic Contact Close
2023-03-09T13:28:49.475975883+00:00 TRACE Z-Wave Device Config Mc  Received event with handler unnamed
2023-03-09T13:28:49.476534050+00:00 INFO Z-Wave Device Config Mc  <ZwaveDevice: 1a8b55d9-9eff-4581-a8b0-4b8c30ee2696 [02] (Nortek Open/Closed Sensor)> received Z-Wave command: {args={value=0}, cmd_class="BASIC", cmd_id="SET", dst_channels={}, encap="NONE", payload="\x00", src_channel=0, version=1}
2023-03-09T13:28:49.486170592+00:00 DEBUG Z-Wave Device Config Mc  Nortek Open/Closed Sensor device thread event handled
2023-03-09T13:28:49.488502967+00:00 TRACE Z-Wave Device Config Mc  Received event with handler unnamed
2023-03-09T13:28:49.490738967+00:00 INFO Z-Wave Device Config Mc  <ZwaveDevice: 1a8b55d9-9eff-4581-a8b0-4b8c30ee2696 [02] (Nortek Open/Closed Sensor)> received Z-Wave command: {args={alarm_level=0, alarm_type=7, event="INTRUSION", event_parameter="", notification_status="ON", notification_type="HOME_SECURITY", v1_alarm_level=0, v1_alarm_type=7, z_wave_alarm_event="INTRUSION", z_wave_alarm_status="ON", z_wave_alarm_type="BURGLAR", zensor_net_source_node_id=0}, cmd_class="NOTIFICATION", cmd_id="REPORT", dst_channels={}, encap="NONE", payload="\x07\x00\x00\xFF\x07\x02\x00\x00", src_channel=0, version=3}
2023-03-09T13:28:49.494762925+00:00 DEBUG Z-Wave Device Config Mc  Nortek Open/Closed Sensor device thread event handled
External Contact Open
2023-03-09T13:29:58.678590541+00:00 TRACE Z-Wave Device Config Mc  Received event with handler unnamed
2023-03-09T13:29:58.681095750+00:00 INFO Z-Wave Device Config Mc  <ZwaveDevice: 1a8b55d9-9eff-4581-a8b0-4b8c30ee2696 [02] (Nortek Open/Closed Sensor)> received Z-Wave command: {args={alarm_level=0, alarm_type=7, event="UNKNOWN_EVENT_STATE", event_parameter="", notification_status="ON", notification_type="HOME_SECURITY", v1_alarm_level=0, v1_alarm_type=7, z_wave_alarm_event="UNKNOWN_EVENT_STATE", z_wave_alarm_status="ON", z_wave_alarm_type="BURGLAR", zensor_net_source_node_id=0}, cmd_class="NOTIFICATION", cmd_id="REPORT", dst_channels={}, encap="NONE", payload="\x07\x00\x00\xFF\x07\xFE\x00\x00", src_channel=0, version=3}
2023-03-09T13:29:58.684650791+00:00 DEBUG Z-Wave Device Config Mc  Nortek Open/Closed Sensor device thread event handled
External Contact Close
2023-03-09T13:30:39.198300019+00:00 TRACE Z-Wave Device Config Mc  Received event with handler unnamed
2023-03-09T13:30:39.208899311+00:00 INFO Z-Wave Device Config Mc  <ZwaveDevice: 1a8b55d9-9eff-4581-a8b0-4b8c30ee2696 [02] (Nortek Open/Closed Sensor)> received Z-Wave command: {args={alarm_level=255, alarm_type=7, event="UNKNOWN_EVENT_STATE", event_parameter="", notification_status="ON", notification_type="HOME_SECURITY", v1_alarm_level=255, v1_alarm_type=7, z_wave_alarm_event="UNKNOWN_EVENT_STATE", z_wave_alarm_status="ON", z_wave_alarm_type="BURGLAR", zensor_net_source_node_id=0}, cmd_class="NOTIFICATION", cmd_id="REPORT", dst_channels={}, encap="NONE", payload="\x07\xFF\x00\xFF\x07\xFE\x00\x00", src_channel=0, version=3}
2023-03-09T13:30:39.214381102+00:00 DEBUG Z-Wave Device Config Mc  Nortek Open/Closed Sensor device thread event handled
Tamper Open
2023-03-09T13:32:28.178367105+00:00 TRACE Z-Wave Device Config Mc  Received event with handler unnamed
2023-03-09T13:32:28.180995314+00:00 INFO Z-Wave Device Config Mc  <ZwaveDevice: 1a8b55d9-9eff-4581-a8b0-4b8c30ee2696 [02] (Nortek Open/Closed Sensor)> received Z-Wave command: {args={alarm_level=255, alarm_type=7, event="TAMPERING_PRODUCT_COVER_REMOVED", event_parameter="", notification_status="ON", notification_type="HOME_SECURITY", v1_alarm_level=255, v1_alarm_type=7, z_wave_alarm_event="TAMPERING_PRODUCT_COVER_REMOVED", z_wave_alarm_status="ON", z_wave_alarm_type="BURGLAR", zensor_net_source_node_id=0}, cmd_class="NOTIFICATION", cmd_id="REPORT", dst_channels={}, encap="NONE", payload="\x07\xFF\x00\xFF\x07\x03\x00\x00", src_channel=0, version=3}
2023-03-09T13:32:28.184551814+00:00 DEBUG Z-Wave Device Config Mc  Nortek Open/Closed Sensor device thread event handled
Tamper Closed
2023-03-09T13:32:57.616315744+00:00 TRACE Z-Wave Device Config Mc  Received event with handler unnamed
2023-03-09T13:32:57.616988786+00:00 INFO Z-Wave Device Config Mc  <ZwaveDevice: 1a8b55d9-9eff-4581-a8b0-4b8c30ee2696 [02] (Nortek Open/Closed Sensor)> received Z-Wave command: {args={}, cmd_class="WAKE_UP", cmd_id="NOTIFICATION", dst_channels={}, encap="NONE", payload="", src_channel=0, version=1}
2023-03-09T13:32:57.618007953+00:00 DEBUG Z-Wave Device Config Mc  Nortek Open/Closed Sensor device thread event handled
Please note the other thread that was split from this thread also.
Thanks for any help!
Just want to clarify on this sensor that it has some differences compared to the Ecolink, at least according to this description. I do not have an Ecolink to verify what this document says but I do have the Nortek/gocontrol: The Nortek reed switch/ external contacts are not in parallel. They do, in fact control two different parameters not an either/or
Hi @valkokir
The problem with this device is that in the driver it uses the default contactSensor handler and to emit the open close event it uses the event:
local contact_notification_events_map = {
     [Notification.event.home_security.INTRUSION_LOCATION_PROVIDED] = capabilities.contactSensor.contact.open(),
     [Notification.event.home_security.INTRUSION] = capabilities.contactSensor.contact.open(),
     [Notification.event.home_security.STATE_IDLE] = capabilities.contactSensor.contact.closed(),
     [Notification.event.access_control.WINDOW_DOOR_IS_OPEN] = capabilities.contactSensor.contact.open(),
     [Notification.event.access_control.WINDOW_DOOR_IS_CLOSED] = capabilities.contactSensor.contact.closed()
And the device always sends the same event = “INTRUSION” and what changes is the alarm_level=0 for closed and alarm_level=255 for open.
Sensor Closed:
2023-03-09T13:28:49.490738967+00:00 INFO Z-Wave Device Config Mc <ZwaveDevice: 1a8b55d9-9eff-4581-a8b0-4b8c30ee2696 [02] (Nortek Open/Closed Sensor)> received Z-Wave command: {args={alarm_level=0, alarm_type=7, event=“INTRUSION”, event_parameter=“”, notification_status=“ON”, notification_type=“HOME_SECURITY”, v1_alarm_level=0, v1_alarm_type=7, z_wave_alarm_event=“INTRUSION”, z_wave_alarm_status=“ON”, z_wave_alarm_type=“BURGLAR”, zensor_net_source_node_id=0}, cmd_class=“NOTIFICATION”, cmd_id=“REPORT”, dst_channels={}, encap=“NONE”, payload=“\x07\x00\x00\xFF\x07\x02\x00\x00”, src_channel=0, version=3}
Sensor open:
2023-03-09T13:27:04.447434241+00:00 INFO Z-Wave Device Config Mc <ZwaveDevice: 1a8b55d9-9eff-4581-a8b0-4b8c30ee2696 [02] (Nortek Open/Closed Sensor)> received Z-Wave command: {args={alarm_level=255, alarm_type=7, event=“INTRUSION”, event_parameter=“”, notification_status=“ON”, notification_type=“HOME_SECURITY”, v1_alarm_level=255, v1_alarm_type=7, z_wave_alarm_event=“INTRUSION”, z_wave_alarm_status=“ON”, z_wave_alarm_type=“BURGLAR”, zensor_net_source_node_id=0}, cmd_class=“NOTIFICATION”, cmd_id=“REPORT”, dst_channels={}, encap=“NONE”, payload=“\x07\xFF\x00\xFF\x07\x02\x00\x00”, src_channel=0, version=3}
For external contact use event=“UNKNOWN_EVENT_STATE” and values are 0 for open and 255 for closed and the default do not handle this event
It would be necessary to modify the diver and add a subdriver to handle the [Notification.REPORT] for this device instead use default handler
I don’t know if the device configuration can change the type of event sent for contacts
While smartthings fixes the stock driver you can try to see if it works with this driver that is on my channel
 Name         Z-Wave Sensor and Child Thermostat TEST
 Version      2023-03-09T15:36:56.027436797
driver deleted, it seems that it is not necessary
Thank you, my error. I have edited my post above.
Hi folks. I tried using the phil30 masquerade driver for my gocontrol sensors. I am trying to use the external inputs of the sensors. The driver seems to work fine for a while but then after some time the state of the driver seems to randomly start showing incorrect state. I wanted to see what the correct driver to use. Given the popularity of this sensor, I am hoping things were resolved.
