Hi, gledopto just got certification of Smartthings Works Product, so it is okay for gledopto and ST. But it will only find gledopto brand on USA account, that’s weird. I think it is ST’s setting to different country?
I think I will send Gledopto an email to clarify integration with Smartthings. It seems there should be no reason why it shouldn’t work but I will check directly with them before buying and testing it.
New Brands/Devices available on the SmartThings Platform (using SmartThings v3 app) In there you can find gledopto brand.
In the new V3 app some devices are region-locked and can only be added if your account location is in a specific country. That was not true with the classic app.
Yea so I’m not on the new app but if I go into it and select add new device, I see Gledopto listed as a brand but when I click into it the only device type available to select is “Switches and dimmers” and within that the only device listed is RGB+CCT LED Controller. So maybe bulbs are region locked for now.
I managed to get the RGB lightbulb (6W bulb GL-B-007Z) working. Steps:
- Screw the bulb and turn it on.
- On the smartthings app, add a new light device, select “IKEA” and leave it searching.
- Turn the light off and on 5 times. After the fifth, the lightbulb with blink 5 times.
- At this point the application should detect the Gledopto light, including the colour capability.
Thanks for that. I received an email back from Gledopto support in Europe confirming that their products do all integrate with Smartthings. In that case I would expect to see bulbs as an option under the Gledopto products in the new app but minor issue I guess.
Just a further update from Gledopto:
"I got update today, only RGB-CCT products are working now.
You can use RGB-CCT Controller also for bulbs and other RGB-CCT product, no problem.
More products will come later, we are in contact with SmartThings about it."
