GitHub IDE integration issues
Hi folks - I can’t seem to get my GitHub repo to integrate with ST. I followed the instructions and set up the repo with the naming convention required including the subdirectory with name.src and name.groovy within it. The repo gets added okay to the IDE but when you try to install the code it returns an error. It says “1 skipped due to errors” but I can’t find what the error is. I can manually add and update the groovy code so I know there isn’t an error in my code. Perhaps someone could try installing it to see if they get the same error? The repo owner is “kewashi” and name is HousePanel on branch master.
