Hi Chals, thanks again for your superb work on making these device handlers. Sorry to have to bother you again.
I’ve been using your Mi Connector for sometime and it’s excellent. I had previously installed a cast-web device handler but it was running inconsistently as I had struggled to add the Node Js to my raspberry pi so used an android tablet instead. I’ve attempted to install your GH connector and have gotten stuck. When I’ve gone into the app and put the IP address I get taken to a login screen? Not sure what to do here or whether I’ve missed something?
Also not sure whether this is the best place to ask but I’ve attempted several times to use my raspberry pi for other purposes. At the minute I’ve only managed to install Hypriot with the Mi Connector on. Everytime I’ve attempted to install something else, I never seem to manage. Thanks again
Thanks for that, I’ve gotten a step further I guess. I can access the SmartApp (to increase the volume, change tracks etc) but none of my devices are being added to my Things list. One did when I first logged in but it crashed the app when you pressed it. Reallly appreciate your help
Hello Fison, Thank you once again for making this. I have set up everything and it seems to work but i would like to set TTS to google. First TTS didn’t work at all. I went into smarthings and choice my speaker in things than in the setting of that speaker i have selected all the TTS options because if i just select google it wouldn’t save. Says fill out all required fields. So my tts works but with an accent it either is using ODDCAST or Naver i believe. I have correctly set up the google tts and google assistant API. How can i tell the speaker which TTS to use? Any ideas?
This was created for Korean users.
So, there is only one voice option for English users.
I updated a DTH a moment ago.
Naver TTS
mijin : Korean, Female
jinho : Korean, Male
clara : English, Female
matt : English, Male
jose : Spanish, Male
carmen : Spanish, Female
ODDCAST
See this site https://www.ttsdemo.com/
Find a name and add it to DTH
exam)
input name: “ttsPerson”, title:"[ ODDCAST ] Select a Person" , type: “enum”, required: true, options: [“dayoung”, “hyeryun”, “hyuna”, “jihun”, “jimin”, “junwoo”, “narae”, “sena”, “yumi”, “yura”, “alan”, “beth”], defaultValue: “dayoung”, description:""
Google Cloud
You can select a Wavenet if you use a English.
You have to select a language on here first >> [ GOOGLE ] Select a TTS language
W-A means >> en-US-Wavenet-A
[GH-Connector] error: Error: Not Found
at /usr/src/app/app.js:147:13
at Layer.handle [as handle_request] (/usr/src/app/node_modules/express/lib/router/layer.js:95:5)
at trim_prefix (/usr/src/app/node_modules/express/lib/router/index.js:317:13)
at /usr/src/app/node_modules/express/lib/router/index.js:284:7
at Function.process_params (/usr/src/app/node_modules/express/lib/router/index.js:335:12)
at next (/usr/src/app/node_modules/express/lib/router/index.js:275:10)
at /usr/src/app/node_modules/express/lib/router/index.js:635:15
at next (/usr/src/app/node_modules/express/lib/router/index.js:260:14)
at Function.handle (/usr/src/app/node_modules/express/lib/router/index.js:174:3)
at router (/usr/src/app/node_modules/express/lib/router/index.js:47:12)
and this one:
(node:23) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 message listeners added. Use emitter.setMaxListeners() to increase limit
Hi @fison67
Are you still active on this connector ?
I’m trying to set up your connector but can’t figure it out.
I’m not brilliant on the pi but I’ve got docker running now but it only ever runs hello world if I put sudo in front.
I’ve gone through all your docker installation for the connector and that seemed to go well with no errors.
I’ve installed the smartapp and enabled OAuth as well as the device handlers.
So then when I go to install the smartapp I’m not even 100% sure what my server address is so I put 192.168.0.100:30010 that I saw mentioned somewhere and that seemed to do something.
But then on the next tab “local management” I click that and get a error page.
I’m not sure what I’m meant to do with that code under API so I copied and pasted it into the terminal but I didn’t get anything.
Can you tell me where I’m going wrong.
i tried to pull the docker image “fison67/gh-connector-rasp:0.0.2” and i got the follow error:
Error response from daemon: manifest for fison67/gh-connector-rasp:0.0.2 not found: manifest unknown: manifest unknown
