Hi
getting started with tiles and DH and have this DH that I’m using to control my roller shutter (shelly 2 module)
I have 2 issues that i don’t know how to solve :
- when operating the roller shutter manually or from the shelly app I get the main tile label as Unknown after pressing the refresh while the percentage value is right.
I can see from the logs that it create the correct event
25c48e96-b67c-4edf-af45-323a09967d14 7:26:30 PM: debug State stop
25c48e96-b67c-4edf-af45-323a09967d14 7:26:30 PM: debug Position 77%
25c48e96-b67c-4edf-af45-323a09967d14 7:26:30 PM: debug Parsing result XXX
25c48e96-b67c-4edf-af45-323a09967d14 7:26:30 PM: debug Refresh - Getting Status
- When I operate the device outside of ST (shelly app or manually ) I’m not getting any logs so the state and percentage stay until I push the refresh on ST (and then I get Unknown but perc is correct )
should I use “Subscribing to device Events” ? How can I see that stat has changed not by ST .
Here is the DH code:
* Shelly 2 as Roller Shutter Device Handler
* Copyright 2018 DUCCIO GASPARRI
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
* Shelly http POST at http://IP/roller/0 (roller 1 does not exist) with body form-urlencoded:
* go=open
* go=close
* go=to_pos&roller_pos=[value 0-100]
* go=stop
metadata {
definition (name: "Shelly 2 as Roller Shutter", namespace: "dgasparri", author: "Duccio Marco Gasparri") {
capability "Actuator"
capability "Sensor"
capability "Refresh" // refresh command
capability "Health Check"
capability "Switch Level" // attribute: level (integer, setter: setLevel), command setLevel(level)
capability "Switch"
capability "Window Shade" // windowShade.value ( closed, closing, open, opening, partially open, unknown ), methods: close(), open(), presetPosition()
// @TODO: this IP or preferences IP?
// attribute "IP", "string"
command "stop"
tiles(scale: 2) {
multiAttributeTile(name:"windowShade", type: "generic", width: 6, height: 4){
tileAttribute ("device.windowShade", key: "PRIMARY_CONTROL") {
attributeState "unknown", label:'${name}', action:"close", icon:"st.shades.shade-closed", backgroundColor:"#ffffff", nextState:"closing"
attributeState "open", label:'${name}', action:"close", icon:"st.shades.shade-open", backgroundColor:"#79b821", nextState:"closing"
attributeState "closed", label:'${name}', action:"open", icon:"st.shades.shade-closed", backgroundColor:"#ffffff", nextState:"opening"
attributeState "partially open", label:'${name}', action:"close", icon:"st.shades.shade-open", backgroundColor:"#79b821", nextState:"closing"
attributeState "opening", label:'${name}', action:"stop", icon:"st.shades.shade-opening", backgroundColor:"#79b821", nextState:"partially open"
attributeState "closing", label:'${name}', action:"stop", icon:"st.shades.shade-closing", backgroundColor:"#ffffff", nextState:"partially open"
tileAttribute ("device.level", key: "SLIDER_CONTROL") {
attributeState "level", action:"setLevel", label:'${currentValue} %'
standardTile("up", "device.level", width: 2, height: 2, decoration: "flat") {
state "default", label: "open", action:"open", icon:"st.shades.shade-open"
standardTile("home", "device.level", width: 2, height: 2, decoration: "flat") {
state "default", label: "preset", action:"presetPosition", icon:"st.Home.home9" //st.Home.home9
standardTile("down", "device.level", width: 2, height: 2, decoration: "flat") {
state "default", label: "close", action:"close", icon:"st.shades.shade-closed"
standardTile("refresh", "device.refresh", width: 2, height: 2, inactiveLabel: false, decoration: "flat") {
state "default", label:'', action:"refresh.refresh", icon:"st.secondary.refresh", nextState: "disabled"
state "disabled", label:'', action:"", icon:"st.secondary.refresh"
preferences {
input("ip", "string", title:"IP", description:"Shelly IP Address", defaultValue:"" , required: false, displayDuringSetup: true)
input("preset", "number", title: "Pre-defined position (1-100)", defaultValue: 50, required: false, displayDuringSetup: true)
input("closedif", "number", title: "Closed if at most (1-100)", defaultvalue: 5, required: false, displayDuringSetup: false)
input("openif", "number", title: "Open if at least (1-100)", defaultvalue: 85, required: false, displayDuringSetup: false)
main(["windowShade"])
details(["windowShade", "up", "home", "down", "refresh"])
def getCheckInterval() {
// These are battery-powered devices, and it's not very critical
// to know whether they're online or not – 12 hrs
log.debug "getCheckInterval"
return 4 * 60 * 60
def installed() {
log.debug "Installed"
sendEvent(name: "checkInterval", value: checkInterval, displayed: false)
refresh()
def updated() {
log.debug "Updated"
if (device.latestValue("checkInterval") != checkInterval) {
refresh()
def parseLanMessage(description) {
log.debug "Parsing result $description"
def msg = parseLanMessage(description)
// log.debug "Lan message $msg"
// headers:[content-length:172, http/1.1 200 ok:null, connection:close, content-type:application/json, server:Mongoose/6.11],
// body:{"state":"close","power":0.00,"is_valid":true,"safety_switch":false,"stop_reason":"normal",
// "last_direction":"close","current_pos":46,"calibrating":false,"positioning":true},
// header:HTTP/1.1 200 OK
def headersAsString = msg.header // => headers as a string
def headerMap = msg.headers // => headers as a Map
def body = msg.body // => request body as a string
def status = msg.status // => http status code of the response
def data = msg.data // => either JSON or XML in response body (whichever is specified by content-type header in response)
log.debug "Position ${data.current_pos}%"
log.debug "State ${data.state}"
def evt1 = createEvent(name: "level", value: data.current_pos, displayed: false)
def evt2 = null
def evt3 = null
if ( data.current_pos < closedif ) {
log.debug "CreateEvent closed"
evt2 = createEvent(name: "windowShade", value: "closed", displayed: false)
evt3 = createEvent(name: "switch", value: "off", displayed: false)
} else if ( data.current_pos > openif ) {
log.debug "CreateEvent open"
evt2 = createEvent(name: "windowShade", value: "on", displayed: false)
evt3 = createEvent(name: "switch", value: "on", displayed: false)
} else {
log.debug "CreateEvent Partially open"
evt2 = createEvent(name: "windowShade", value: "partially open", displayed: false)
//log.debut "Parsed to ${evt1.inspect()} and ${evt2.inspect()}"
return [evt1, evt2, evt3]
def open() {
log.debug "Executing 'open'"
sendRollerCommand "go=open"
def close() {
log.debug "Executing 'close'"
sendRollerCommand "go=close"
//switch.on
def on() {
log.debug "Executing switch.on"
open()
//switch.off
def off() {
log.debug "Executing switch.off"
close()
def setLevel(value, duration = null) {
log.debug "Executing setLevel value with $value"
sendRollerCommand "go=to_pos&roller_pos="+value
def presetPosition() {
log.debug "Executing 'presetPosition'"
setLevel(preset)
def stop() {
log.debug "Executing stop()"
def ping() {
log.debug "Ping"
refresh()
def refresh() {
log.debug "Refresh - Getting Status"
sendHubCommand(new physicalgraph.device.HubAction(
method: "GET",
path: "/roller/0",
headers: [
HOST: getShellyAddress(),
"Content-Type": "application/x-www-form-urlencoded"
def sendRollerCommand(action) {
log.debug "Calling /roller/0 with $action"
method: "POST",
path: "/roller/0",
body: action,
headers: [
runIn(25, refresh)
private getShellyAddress() {
def port = 80
def iphex = ip.tokenize( '.' ).collect { String.format( '%02x', it.toInteger() ) }.join().toUpperCase()
def porthex = String.format('%04x', port.toInteger())
def shellyAddress = iphex + ":" + porthex
device.deviceNetworkId = shellyAddress.toUpperCase()
log.debug "Using IP " + ip + ", PORT 80 and HEX ADDRESS " + shellyAddress + " for device: ${device.id}"
return device.deviceNetworkId
Thanks to dgasparri who Created this DH
