Getting the Source IP Address in parse() method?
I have LAN-connected devices that will send messages to SmartThings Hub which will be passed to my device-handler’s parse() method
Is there a way to know the IP address of the caller? The parseLanMessage doesn’t have the source IP address.
def parse(description) {
def msg = parseLanMessage(description)
def headersAsString = msg.header // => headers as a string
def headerMap = msg.headers      // => headers as a Map
def body = msg.body              // => request body as a string
def status = msg.status          // => http status code of the response
def json = msg.json              // => any JSON included in response body, as a data structure of lists and maps
def xml = msg.xml                // => any XML included in response body, as a document tree structure
def data = msg.data              // => either JSON or XML in response body (whichever is specified by content-type header in response)
In my app (using UDP comms), I use the below code:
def parseDeviceData(response) {
	def resp = parseLanMessage(response.description)
	def deviceIp = convertHexToIP(resp.ip)}
Then
private String convertHexToIP(hex) {
	[convertHexToInt(hex[0..1]),convertHexToInt(hex[2..3]),convertHexToInt(hex[4..5]),convertHexToInt(hex[6..7])].join(".")
If you are using TCP, It will look something like the below (evt is the same as response in yours).
def parsedEvent = parseLanMessage(evt.description)
logDebug("ssdpHandler:  parsedEvent = ${parsedEvent}")
def ip = convertHexToIP(parsedEvent.networkAddress)
There are other possible variations, just play around with it.
