Hi and thanks in advance. I am trying to write a SmartApp that detects water and turns on some lights. But I also want to read its temperature and battery level. So I have:
preferences {
section("When Water Is Detected Here:") {
input "water", "capability.waterSensor", title: "Water Sensors", required: true, multiple: true
section("Turn On These Lights/Switches:") {
input "switches", "capability.switch", title: "Lights/Switches", required: false, multiple: true
def installed() {
log.debug "Installed with settings: ${settings}"
initialize()
def updated() {
log.debug "Updated with settings: ${settings}"
unsubscribe()
initialize()
def initialize() {
subscribe(water, "water", myHandler)
//Get the capabilities and attributes of the water sensor
def mySensors = water.capabilities
mySensors.each {cap ->
log.debug "Capability name: ${cap.name}"
cap.attributes.each {attr ->
log.debug "-- Attribute name; ${attr.name}"
def myHandler(evt) {
if(evt.value == "wet") {
log.debug "Water Detected"
switches.on()
log.debug "Switches On"
//Get Temperature and Battery Level
log.debug "Temperature: ${evt.temperature.value}"
log.debug "Battery Level: ${evt.battery.value}"
When I check to see what capabilities and attributes the water sensor has, the output is this:
debug – Attribute name; [checkInterval]
debug – Attribute name; [water]
debug – Attribute name; [battery]
debug – Attribute name; [temperature]
debug Capability name: [Temperature Measurement, Battery, Water Sensor, Configuration, Refresh, Health Check]
However, when I try to get the Temperature Measurement or the Battery Level, I get this error:
groovy.lang.MissingPropertyException: Exception evaluating property ‘value’ for java.util.ArrayList, Reason: groovy.lang.MissingPropertyException: No such property: value for class: physicalgraph.app.AttributeWrapper
Possible solutions: name
I’m new at this so I don’t know what I’m missing. I don’t want to have to select the Water Sensor 3 times to be able to read its different attributes. How can I read the other attributes of the water sensor while only having the single input?
