The getLabel() method works well in SmartApps to provide the label of a device, but this doesn’t work in a device handler. I need to get the label of one of the tiles defined within the same device handler in my parse function. I have the device name, but need the friendly label I set.
Does anyone know how I can get the label of a device tile within a device handler?
You could try getMetadata() which gets a map of the metadata which should contain an entry for the tiles. I’ve not really tried it or know if it will suit your needs.
I have to include the disclaimers about it not being something that was necessarily supported/documented, so YMMV and can’t guarantee it will work to fit your needs or continue working… but if you don’t mind living dangerously
