Yes, ST broke it. Can’t seem to fix it. I did rewrite the code and got it working, but don’t really want to release it since the old code worked just fine.
It’s really stupid, but it maybe a documentation / platform / no one bothered to test it cause localhub actions aren’t really supported kind of thing…
Thanks so much for the work on this Patrick! I am however running into a bug where I can get one of my cameras to work perfectly, but my second dlink 930L just hangs when I press the “Take” button.
I’ve confirmed that I have the correct IP address and everything else is duplicate of the working camera. I can also access the static image of the problem camera in my local web browser. So do you have any ideas what could be causing this?
I’d really appreciate it and thanks again for the work on this device type!
@pstuart - Am I to understand that this app is currently broken? Mine has stopped working, and I’m not going to bother troubleshooting it if it’s a known issue.
Unfortunately, no, its a sloppy hack that could break anytime. ST has way too many “priorities” and not enough developers to take the time out of their schedules to figure out what they broke for many users of cameras.
It has been a month and a half since they broke the s3 parsing code of the platform and can’t take the time it would take to revert their code to fix this.
Even if I released my workaround, I suspect they will break that as well.
I’m not happy about it, but that is my perspective. I’ve pushed every button, @ben, @april, @Tyler etc I can to try to get this fixed and today was the last straw when I get an email from support saying they don’t have the resources to look into it let alone fix it until Q3. WTF?
Sorry guys, I think this devicetype has been unofficially killed until further notice.
Still can’t view images from the Android app but it works from the IOS app which is good enough. Thanks for your continued work on this @pstuart! Your efforts here make my house work better and I really appreciate it.
Which android version? If you don’t mind, try force quiting the app and relaunching it see if cameras work again on android. Sometimes the image carousel glitches.
Restarting the app on my Nexus 5 phone doesn’t make any difference (carousel just displays the SmartThings logo), but trying it on my Nexus 7 tablet works as expected. Both are running 5.1.
For those still having issues, please upgrade to the latest android 1.7.3 just released:
and let me know if it isn’t working still. Mine started working with this release. Plus the images are now in the correct order.
If you are still having issues, please let me know make and model of your android device (os as well) and make and model of your camera and path you are using to image and if its post or get and if it requires auth or not.
Thanks for your patience… ST thanks for getting this fixed
My setup works fine on my wife’s iPad, and always has. It still does not work with the latest 1.7.3 version on my Verizon Samsung Galaxy S5 on Android 5.0, or my wife’s S4 that was just upgraded to 5.0.1 this week. So it does not look as if the carousel issues are fixed for all platforms. Since the images show on IOS, I take that as to mean that the device type code works fine, and the images show up where they should. I can’t see how the device code can “fix” the Android issue, unless it has to do with the naming of the image. Please correct me if I misunderstand something.
FWIW, I use a derivation of what I assume is the original IP device type that uses digest auth with a GET.
I have a couple of Samsung cameras. What device type code are you using for your Foscam?
I had an older Android phone that I used to use as an IP camera, and it worked better - pictures would show in the carousel but not without a refresh. That camera device type did not use the local connection, which is what I use for the Samsung IP cameras.
As mentioned earlier, things work fine on the wife’s iPad. I don’t what other conclusion to draw other than the issue is with the Android app.
Finally success! I spent another couple hours messing with this over the weekend and it started working when I changed the picture name. I noticed the function that was used, makes the picture name by combining the DNI with a UID. The DNI has a ‘:’ in the name. I took out the DNI from the picture name and the pictures started showing up in my Android app carousel. Go figure.
