I have GE Z-Wave Wireless Lighting Control Lamp Module connected to three, tower, high intensity floor lamps. It’s been working great for a year…
2 weeks ago I unplugged the controller and lamps to paint the room. When I put it back, the behavior of the GE lighting controller changed. Now, when it comes on at 100%, whether manually or by the SmartThings app, it will turn itself off after a second or two. If I set the dimming to anything under 100% (even 99%) the light stays on…
Can these controllers get damaged? Anyone have any ideas?
This problem may indicate an overloaded circuit, a loose neutral, a bad connection, or the device going bad.
Paint may have gotten into one of the outlets on the circuit and you’re getting a short or a poor connection. Or a connection may have been knocked loose.
I would try the module in another room on another circuit. Use a GFCI receptacle. If you see the same dimmer behaviour, the module’s likely going bad. If you don’t, have an electrician check the first circuit.
