Provided your items are fairly new (Z-Wave Plus), we made switch mode available on our dimmers. If your fixtures are within spec of the dimmer’s ratings, feel free to use it as a switch! To enable switch mode, tap the top button 5 times then tap the bottom button 5 times. The LED will signify it was successful by blinking 3 times at you. You can switch back to dim mode by doing the same.
