GE Z-wave Dimmer - lights are fully bright at about 40%
Hello! I have recently started installing these smart home devices. I put 4 of the GE Z-wave paddle dimmers in. On one overhead light (3 dimmable LED bulbs), the bulbs are at full brightness right around 38-40% dimming (according to the app). On the lights in another room it is similar but up around 70%. The other two seem normal; dimming basically from 0-100% as I’d expect. Does anyone have any suggestions for what the issue might be, or how to best troubleshoot it?
You may want to login to IDE at https://account.smartthings.com go to My Devices and see what device handler they are using
could be the bulbs you are using?
This would be my guess. LEDs that are non-dimmable are fully bright around 30% with all my dimmers. Had the same issue with some landscape lights. Switched the bulbs out and I get full range.
Thank you! I thought sure I used the dimmable LEDs (fixture is brand new), but maybe I grabbed the wrong ones. I’ll check the device handler too. I really appreciate the suggestions.
