Hey guys,
Give this a try as a device handler for the GE Link bulbs. There are still a couple of issues with it remembering the dimmer level between on/off cycles but works other than that. Improvements and/or fixes appreciated
* ZigBee GE Link Bulb
* Copyright 2014 Chad Monroe
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
* capabilities:
* actuator
* configuration
* polling
* pefresh
* sensor
* switch
* switch level
metadata
definition( name: "ZigBee GE Link Bulb", namespace: "cmonroe", author: "Chad Monroe" )
capability "Switch Level"
capability "Actuator"
capability "Switch"
capability "Configuration"
capability "Polling"
capability "Refresh"
capability "Sensor"
fingerprint( profileId: "0104", inClusters: "0000,0003,0004,0005,0006,0008,1000", outClusters: "0019" )
/* simulator metadata */
simulator
/* status messages */
status "on": "on/off: 1"
status "off": "on/off: 0"
/* reply messages */
reply "zcl on-off on": "on/off: 1"
reply "zcl on-off off": "on/off: 0"
/* ui tile definitions */
tiles
standardTile( "switch", "device.switch", width: 2, height: 2, canChangeIcon: true )
state "off", label: '${name}', action: "switch.on", icon: "st.Lighting.light13", backgroundColor: "#ffffff"
state "on", label: '${name}', action: "switch.off", icon: "st.Lighting.light11", backgroundColor: "#79b821"
standardTile( "refresh", "device.switch", inactiveLabel: false, decoration: "flat" )
state "default", label:"", action:"refresh.refresh", icon:"st.secondary.refresh"
controlTile( "levelSliderControl", "device.level", "slider", height: 1, width: 3, inactiveLabel: false )
state "level", action: "switch level.setLevel"
valueTile( "level", "device.level", inactiveLabel: false, decoration: "flat" )
state "level", label:'${currentValue} %', unit:"%", backgroundColor:"#ffffff"
main(["switch"])
details( ["switch", "refresh", "level", "levelSliderControl"] )
/* parse incoming device messages to generate events */
def parse(String description)
/* log.trace description */
if ( description?.startsWith("catchall:") )
def msg = zigbee.parse(description)
log.trace "catchall"
log.trace msg
log.trace "data: $msg.data"
else
def name = description?.startsWith( "on/off: " ) ? "switch" : null
def value = name == "switch" ? ( description?.endsWith( " 1" ) ? "on" : "off" ) : null
def result = createEvent( name: name, value: value )
log.debug "parse returned ${result?.descriptionText}"
return result
def on()
def cmds = []
def level = device.latestValue( "level" ) as Integer ?: 0
log.trace "on(): lastLevel=${level}"
if ( ( level > 0 ) && ( level < 100 ) )
def levelHex = new BigInteger( Math.round( level * 255 / 100 ).toString()).toString( 16 )
log.trace "on(): lastLevel=${level} valid, restoring to level=${levelHex}"
sendEvent( name: "level", value: level )
sendEvent( name: "switch.setLevel", value: level )
//cmds << "st cmd 0x${device.deviceNetworkId} ${endpointId} 6 1 {}"
cmds << "st cmd 0x${device.deviceNetworkId} ${endpointId} 8 4 {${levelHex} 0000}"
else
sendEvent( name: "level", value: 99 )
sendEvent( name: "switch.setLevel", value: 99 )
log.debug "on(): zigbee cmds: ${cmds}"
cmds
def off()
def cmds = []
log.trace "off()"
sendEvent( name: "switch", value: "off" )
cmds << "st cmd 0x${device.deviceNetworkId} ${endpointId} 6 0 {}"
log.debug "off(): zigbee cmds: ${cmds}"
cmds
def refresh()
def cmds = []
log.trace "refresh()"
cmds << "st rattr 0x${device.deviceNetworkId} 1 6 0"
log.debug "refresh(): zigbee cmds: ${cmds}"
cmds
def poll()
log.debug "poll(): calling refresh()"
refresh()
def setLevel(value)
def cmds = []
def level = value as Integer
log.trace "setLevel($level)"
if ( value == 0 )
else if ( device.latestValue( "switch" ) == "off" )
sendEvent( name: "switch", value: "on" )
log.debug "setLevel(): zigbee cmds: ${cmds}"
cmds
private hex(value, width=2)
def s = new BigInteger(Math.round(value).toString()).toString(16)
while ( s.size() < width )
s = "0" + s
s
private getEndpointId()
new BigInteger(device.endpointId, 16).toString()
