Gah! Wonder what the hold up is? Waiting until the new line of switches come out?
Getting close?
https://www.aartech.ca/product/00/37792/Jasco-ZWave-Plus-Hub-Controller-Remote-2-Button
The suspense is killing me. So far nothing, but Iām going to give them another week at the most. If they donāt deliver, then I am finally going to throw in the towel and go Hubitat / Lutron Pro bridge so that I can use Pico remotes instead.
Why not use the Eria Switch: (Itās Zigbee):
Pico Remotes on Hubitat are amazing! And now that Lutron has bumped the max devices from 50 to 75 on the SmartBridge Proā¦ What amazes me since switching to Lutron Clear Connect for all of my switches, dimmers, and fan controllers is just how they always work. Theyāve never failed me thus far. I ripped out a bunch of old GE/Jasco Z-Wave (not plus) devices and I have never been happier. Those devices used to fall off the mesh from time to time, and I always had to re-pair them.
The Dark Side awaits you!!!
Yes thatās a good zigbee option. Hereās a video of the install if you guys find it useful
Well, just ordered 4 as well as a Hubitat so that I can have them execute local. I have a bigger zwave mesh, so was waiting for the Jasco, but looks like itās time to expand the ZigBee mesh.
So, I missed the part where the Eria switches donāt work directly with SmartThings and I have to go via a Hue hub first, which I found out after trying to pair my first Eria switch. I did grab a Hubitat too, so before I do anything else, I am going to try and pair it to that and see what the experience is like.
Now that July is almost over, is there any update on the Jasco switches? I still feel like those are the best option for my needs.
If you go to Hubitat, the Lutron Picos will probably be your best bet. They work great on that platform. ( youāll need a SmartBridge pro for integration, but everything will be local, not cloud to cloud like the SmartThings integration.)
There are multiple Forms available, including a 2 button, a four button, and a dimmer style, and come in white, ivory, or black. And you can get custom engraving from some dealers.
But talk to the folks in the Hubitat community, they can tell you whatever you want to know about that option.
Eria uses standard zigbee, so they should work, but may require a manual change in device handler or maybe even a custom one. What did they pair as?
Thatās just it, they arenāt paring. Iāve tried just about every combo of button presses / lengths possible, but none of them register to SmartThings ā¦ nor can I seem to get them to register in Hubitat either. That may be an indication that I am doing something wrong, so Iām not throwing in the towel yet, but Iām close. If I could at least get it to show up as a Thing that would be me hope, but right now Iāve got nothing.
yeah, sounds like it isnāt going into pairing mode? itās zigbee 3.0, so at the minimum it should pair as a thing
Canāt say about Hubitat, but with SmartThings itās probably a channel issue. Go to the IDE and see what Zigbee channel you are on.
Also, which model hub are you using?
An update ā¦
No luck at all with ST, but got it paired as a button controller with Hubitat. Looks like Iāll be able to make them work with what I need to do. Thanks all for the advice!
Got samples today. Anyone want to help me writing a device type handler? Or know if one may exist?
Logan
Model numbers?
Assuming itās this one, 34172:
https://products.z-wavealliance.org/regions/2/categories/18/products?company=356
Although they call it a āscene controllerā it is not using either of the 2 z wave command sets, local scenes or central scenes. Itās just using association.
So it should be very similar to a minimote, but with a different number of buttons.
( if itās a different model number, it could have completely different firmware even if it uses the same case, so thatās just something to be aware of.)
BTW, The reason they can say āwithout a hubā on the box is because, again just like a minimote, this device can act as a controller on its own if you donāt have another hub. If you do have another hub, it becomes a secondary controller.
Cool. So these will be out for sale, soon. Been waiting a while, hope it was worth the wait.
Iāll be honest, I am disappointed that they rely on Z wave direct association rather than central scenes. You should end up being able to do the same thing, but the setup will be much more complicated and may confuse people.
