Hey everyone,
I recently added a GE45602 module to my setup. The one thing I’ve noticed is that when I turn the light off, a small amount of electricity is still going to the light bulb. Has anyone else experienced this? Is there anything that can be done about this?
This happens when the draw is very low on the pocket socket, so it’s common when you’re using them with LED bulbs.
It sounds weird, but the easiest way to fix this is to plug-in a phone charger into the other receptacle on the device. That will usually increase the draw enough that the switch will actually turn off. Which I know is counterintuitive, it’s just the way these work.
