I just ran into an issue where one of the boxes where I was going to install a smart switch doesnt have the whites tied together. See images below, The other 2 boxes do however is this just a misstep by the electrician who installed it? Can i join the whites together or is there something I should test first.
I pretty much gave up on this topic as I couldn’t get an electrician that would tell me anything other then its working why do I care about the whites.(had two different people come out) The way the circuit works according to what I can tell is this… A switch at my basement receives the power from the breaker, that feeds up to my switch in a closet (where the whites are not connected) from that it goes to the next switch in my garage where whites are connected from there it goes to a light socket where the light socket has a 2 blacks, and 2 whites connected. How do i test if it is safe to connect the whites? Just test voltage from whites to ground make sure there isnt a voltage difference between the two, then test from black to white validate its 115 - 120v?
I had another electrician make it out to the house today. After he looked at it he could only come up with that some where there is a junction box, and within that box the whites are not connected. He gave me the suggestion to go right above where the light switch that does not have the white connected and see what I can find. Well he was 100% right. There was a box, and the whites were cut super short for the runs down to this specific light. It looks to me like this light switch was added after the house was built. So this afternoon I replaced the box, and now have neutral to this switch! Everything is working and I plan to wire in my 4 way GE’s tomorrow as tonight has been enough work for the day.
Before :
You can see that two whites are tied together, however there are 4 wires that come into this box! The other two are cut off you can see in the next picture.
Completed this tonight everything went well Super happy
(main switch) In Wall Smart switch Ge 12711
Pretty much the wiring went as follows… Isolate the main switch power, then add the “Line” wire to the the line port on the Smart switch (non add-on) , Add the other black wire to the load side of the first switch, then add the red wire to the traveler port. Attach the white pig tale to the group of whites in the back of the box and the nutral port on the switch. Connect ground to ground port.
(4 Way Switch ) – Use Add-on 12711 in wall
Connect all blacks together with wire nut or wego push connectors( Do not connect to switch). Connect white wires and a pig tale, then connect to neutral on add-on switch. Connect the reds together then also pig tale, connect pig tale to the Traveler on the add-on switch. Connect neutral to switch.
Last Switch – Use Add-on 12711 in wall
Connect blacks together do not connect to switch. Pig tale the white’s and add to neutral of the add-on switch. Connect Ground to the switch, and then connect the red wire to the traveler on the add-on switch.
