First, a couple of questions about your current set up.
When’s the last time you ran a Z wave repair, and what, if any error messages did you get?
Second, do you have the Aeotec Sensor set up so that you are walking across the detection field rather than straight on towards it?
Third, is the automation that you are using to trigger the device set up to run locally or in the cloud?
Fourth, what’s the firmware level on the multi sensor, if you know. And what’s the exact model number? You can change the configuration of the sleep., Which is often perceived as being a more responsive device.
( because the GE device is mains powered rather than battery powered, it shouldn’t have a sleep period, So in that sense it should be more responsive. But because you have fewer choices about where to place it, that can be an issue separately.)
