I am having trouble pairing Sylvania Gardenspot lights. I have done the reset several times and it keeps coming up as unknown device…any suggestions?
Have you tried logging into the IDE and changing the device to the right one?
Looks like it’s listed as OSRAM LIGHTIFY Gardenspot mini RGB
http://graph.api.smartthings.com
My Devices
Find the unkown one and click on it
Edit it. Choose the right type (above) and save
Close out the ST app and reopen. See if that works then
I have this device as well.
Switching to the OSRAM LIGHTIFY Gardenspot mini RGB device type will give you full control.
I confirmed that this device pairs correctly on my setup. Send me a PM if you’re having trouble pairing this device out of the box.
Thanks that did the trick. When I bought the hub I thought you could only update devices from the app.
You can change the “Device Type” on our developer site. There’s no good reason the device shouldn’t have paired properly though!
Ugh…
I purchased this and plugged them in, they paired right away without issue, showed up with the right device type and everything and it was all good as far as control went.
For two days.
Now ST sees the device, but it can’t control it. I see the events in the log, but nothing happens to the lights – can’t turn them on / off, can’t change color or intensity.
I just wish things would work, all the time.
Hi everyone, i cant find the OSRAM LIGHTIFY Gardenspot mini RGB device type in IDE, any ides of why?
Thanks!!
